E- Locker issues - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 07-31-2010, 01:54 PM Thread Starter
OlegRock's Avatar
E- Locker issues
Recently for no reason that I can find or think of my rear locker dash signal is messed up.
When I lock the rear with the factory switch it ONLY flashes- but the locker IS on. When I switch the rear locker with the locker switch mod the rear locker IS on but it doesn't light up at the dash at all!
OlegRock is offline
post #2 of 3 Old 08-01-2010, 01:33 AM
I've seen that. I've pushed the button and for sure was locked up but the dash 'lock' icon is blinking. WTF? But after a few minutes it 'normals up' and the light is solid. Strange.
post #3 of 3 Old 08-01-2010, 06:28 AM
Prope's Avatar
Loosen your plunger a bit and it will read that it is fully locked & hopefully that works for you.
However, I bet that it really isn't fully engaging and once you put some torque on it it will pop out. If this is the case put some shims between the magnet and the locker engagement fingers and that will fix it. I did a (kinda) write up on it.
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
