2010 Wrangler JKU - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 09-21-2016, 03:51 PM Thread Starter
Exclamation 2010 Wrangler JKU
Hi recently I was driving at night and both head lamps went out. I was able to use the fogs to get home. The bulbs are stock no mods. I did notice the lights flash about three times or so and then go out. I did pick up a multi function replacement switch from the dealer so that I can replace, just wondering if any one else has had the same issue?
Jeep3r is offline
post #2 of 5 Old 09-21-2016, 04:11 PM
Check the connections behind the headlight too. I have replacement IPF headlights & once in awhile after wheeling, the pigtail connectors become lose causing the lights to go out.
2014 Black JKR on 35s
Dirtysocks is online now
post #3 of 5 Old 09-21-2016, 05:56 PM Thread Starter
I went out to get my tools hit the unlock button on the remote and now they are working again, confused
Jeep3r is offline
post #4 of 5 Old 09-21-2016, 10:26 PM
Is your battery healthy?
Danthephotoman is offline
post #5 of 5 Old 09-22-2016, 05:44 AM
^X2
Battery heading south , belt tightening ( maybe needing replacement ) as weather cools can push an already aged alternator to its final failure slowly but w odd symptoms or the corrosion at battery terminals could be building up or loosened .
I had the tiniest hairline crack in my OEM battery you couldn't see around base of negative terminal that caused funky inconsistant behavior until I caught it and replaced w one of the last diehard platinums
