Electrical Gremlins!!!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 07-10-2010, 08:15 PM Thread Starter
So both my battery and my alternator both went out on my 07 jeep jk...I thought? I replaced both of them and now I am getting all kinds of electrical trouble. When I am driving my cluster goes nuts...speedo and tach both start bouncing and every possible engine light comes on. I checked this with my Hypertech programmer and I got the following code. P0000, U0001, P30D1, P1330, U1403, B30D1, P0CB0, U110E. Please I need some help.
Briou is offline
post #2 of 14 Old 07-11-2010, 08:49 PM Thread Starter
also my sway bar disconnect light is blinking and pressing the button to lock/unlock the sway bar does nothing.
Briou is offline
post #3 of 14 Old 07-11-2010, 10:40 PM
Hasen't happened to me so I'm talking out my ass here a little bit. But I've read others post that the swaybo-disko has caused issues like this.
PM BODYGUY - he has written about this issue and may be able to help.
His profile....
https://www.jkowners.com/forum/member.php?u=1629
Welcome to JKO
post #4 of 14 Old 07-12-2010, 10:53 PM Thread Starter
Thanks for the help man...it is funny I joined a year ago but never really get on here so i am still a newbie to the fourm...Thanks again
Briou is offline
post #5 of 14 Old 07-13-2010, 11:37 AM
bodyguy's Avatar
Try disconnecting the harness going to the sway bar. See if that changes anything. When I get home I'll look for my post with all the trouble codes.
bodyguy is offline
post #6 of 14 Old 07-14-2010, 02:36 PM Thread Starter
I disconnected the harness going to the swaybar disconnect and water started pouring out and the connector was fried. I think this is going to eliminate some of the problems but I will keep you updated. Thanks for all your help.
Briou is offline
post #7 of 14 Old 07-14-2010, 05:10 PM
bodyguy's Avatar
It's crazy what can be effected by that circuit. Disconnect your battery for a couple of minutes and then reconnect it start it up and see how it is. That will erase any short term memory
bodyguy is offline
post #8 of 14 Old 07-14-2010, 05:25 PM
tkob1060's Avatar
I had same trouble and disconnecting sway bar connector solved it
tkob1060 is offline
post #9 of 14 Old 07-15-2010, 12:03 AM Thread Starter
haha someone needs to tell jeep about this problem...does anyone know how much a new connector is and possibly a new disconnect motor/solenoid or what ever it is called is? I'm too scared to call the dealership...lol
Briou is offline
post #10 of 14 Old 07-15-2010, 12:08 AM
HA! - Thanks bodyguy I knew that you had the fix for this
post #11 of 14 Old 07-15-2010, 12:13 PM
bodyguy's Avatar
its not the connector, its the moisture that gets in the connector and in the sway bar motor circuit board.
bodyguy is offline
post #12 of 14 Old 07-15-2010, 12:52 PM Thread Starter
Well I know it is the moister that it the problem, it is just that the moister that got into my connector shorted it out and the plastic melted. I am still not sure if the disconnect actuator is fried or not but I called the dealership and a new actuator is $1600. They also said that I would have to bring it in to get the connector fixed....sounds like they are going to look for more problems to suck some more $$$ out of me. But for now I have it running good so I guess I will do without full flex for a while. Thanks again every one for your help. Especially to Bodyguy and TEXASKEV for the referral.
Briou is offline
post #13 of 14 Old 07-18-2010, 07:08 AM
virtual_mage's Avatar
just save yourself the big bill and buy a quick disconect or a currie antirock if you dont fell like disconect it each time,down the line you wont regret it.
virtual_mage is offline
post #14 of 14 Old 06-23-2012, 12:41 PM
So I had the same problem! And pulled the plug off and it was fried! I am not going to the dealer and I have quick discos! But what did y guys do w the open plug did u connect it back in or cut it off or what so the problem dosnt happen again?
2008 yellow rubicon unlimited
Rock krawler 2.5 stock mod w bilstines 5100's, and bikini top. black steelies 15's w 35's kumho road venture, trimmed bumpers and half the flenders
89 cherokee
helpless shell
97 wrangler
old DD
sold for gas money!
jeepmedic08 is offline
