'NO BUS' ERROR HELP!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 07-09-2010, 10:45 PM Thread Starter
v10kingsnake's Avatar
Drove the JK down to SC today with zero issues. Got over to my house to unload some shit and when we went to get back in I noticed the keyfob wasn't working at all. No lock/unlock or autostart or panic functions working. Then I noticed the interior light not coming on when I opened the door???? I put the key in the ignition and turned to 'on' position and everything lit up as normally. I tried to crank it to run and nothing occured! That's when I noticed the No Bus error on the ODO gauge. WTF is wrong here?
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #2 of 7 Old 07-09-2010, 10:47 PM
Hmm, sounds sketchy. Do a battery reset, it's a shot in the dark, but works wonders on the turds I work on (BMW) when we have communication issues. disconnect the negative from the battery, touch it to the positive for a few seconds. (make sure the negative has nothing touching the battery!)
post #3 of 7 Old 07-09-2010, 10:48 PM
Broncojohn's Avatar
Check your connections at the ECU, something may have come loose.
Broncojohn is offline
post #4 of 7 Old 07-10-2010, 09:12 PM Thread Starter
Winner winner chicken dinner!!! You were right. Battery reset and she cranked right up!
post #5 of 7 Old 07-10-2010, 09:37 PM
BumpInTheRoad's Avatar
You been playing in deep water recently? Sounds like your ECU got fubar. Might want to check the connections to your ECU, maybe apply a little silicon grease around the perimeter of the plug to keep water out.
I'm a JKO Reject
BumpInTheRoad is offline
post #6 of 7 Old 07-10-2010, 10:02 PM
Jaws's Avatar
SC air, take it back to NJ.
Jaws is offline
post #7 of 7 Old 07-10-2010, 10:06 PM
That'll be $50 sir lol
