quick switch question for lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 07-02-2010, 12:14 AM Thread Starter
I was thinking about this earlier and thought id get a second, third, even forth or fifth opinion...
I want to add a few sets of extra lights of course. Id like to put switches for the lights and whatever else I may add on the drivers side dash above the speaker. I was thinking it would be cool to have one big main cut off switch so I could hit it in a hurry and shut all the extra lights off (say I have a set or two on for some reason and meet a vehicle I dont have to search for switches to shut them off)
What I was thinking was run a main power to the main switch, then jumper it over to the other switches. Then have those switches simply activate an individual relay to turn on the individual sets of lights rather than having the voltage from the switch go directly to the lights.
Would I still need to take into consideration the amperage that the lights are drawing versus how much amperage the switch can handle, or would I just need to consider the amperage of the relays themselves since the voltage in the switches are simply activating the relays.
Hope Im clear on what im asking.
Also, Ill put in a fuse block which is where the individual relays will get their power source to send to the lights.
No more Jeep
Sunburst Sahara is offline
post #2 of 5 Old 07-03-2010, 09:32 AM
I'm running 4 sets of lights with a kill switch. I thought about running the ground or power thru the switch... Then decided that due to my layout (switches are located over the review mirror, while kill switch is where the power window switches would be), that wouldn't work (I didn't want to run wire all over the place). I ended up using a relay to send the power to the switches above the mirror, and the kill switch activates that relay.
2012 Silver JKU Rubicon
5 speed auto, 4.10s
Riptide is offline
post #3 of 5 Old 07-03-2010, 09:52 AM
edivebuddy's Avatar
If there's a switch, IMO there should be a relay. Cut off switch to a relay that powers lights and other switches.
edivebuddy is offline
post #4 of 5 Old 07-06-2010, 03:30 AM Thread Starter
a switch that operates a relay in order to operate a couple switches that operate their own relays? The main switch would only send power to the other switches. Then the switches would operate relays
I think thats a little overkill... I mean, I would have power wire from the batt. to the switch, then a wire from switch to the relay, then a wire from the batt. to the relay, and a wire from the relay to the other switches. Seems like alot of unnecessary back and forth...
No more Jeep
post #5 of 5 Old 07-06-2010, 03:55 AM
Loki646's Avatar
Give the guys @ Spod a call and ask them directly about running an interrupter switch between the battery and their relay board. It sounds like this is basically what you are trying to do. I can do it with my switch panel, only because of the type of switch panel it is (ARC 8000 - my install). However, Spod is a supporting vendor and having met and talked to them @ Jeep Beach, I would recommend them over what I'm using, they know their stuff and can give you dead on answers.
Loki646 is offline
