Need to find a hot wire for the fog lights?. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 07-01-2010, 08:32 PM Thread Starter
I need to find a hot wire for my fog lights that go on and off with the key?. I need to tap into that. Any where close by the batter?. Thanks
Rescue Green 08 4 door
Rusty's 3.25 coils
JKS rear adjustable track bar
JKS front adjustable track bar
Teraflex adjustable lower control arms
Teraflex steering stablizer
Rough Country 2.2 shocks
Spidertrax 1.5 wheel spacers
BFG 315/70/17 All terrian's
MBRP light bar
KC slim driving lights
Rugged Ridge tail light guards
Rugged Ridge fuel door cover
Rugged Ridge wheels
Smittybuilt XRC 8 winch
Smittybuilt XRC front bumper
Smittybuilt XRC rear bumper/Tire carrier
cvjoint is offline
post #2 of 24 Old 07-02-2010, 12:17 AM
are you looking for a wire that is hot only with ignition on to trigger a relay for an extra set of fogs?
No more Jeep
Sunburst Sahara is offline
post #3 of 24 Old 07-02-2010, 06:13 AM Thread Starter
Yes. I don't want my aftermarket fogs to stay on when the jeep is on. Thanks
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #4 of 24 Old 07-02-2010, 07:36 AM
dmhines's Avatar
Pink/White wire under steering column ...
2009 JK - 2DR - 6SPD - 1/2 Doors
4.88 G2 Gears / Warn XD9000i / Custom bumpers & Swing Gate
XRC Rock Rails / 35" Kumho's on Black Rock Vipers
2.5" Mutt Lift / Rubicon T-Case / E-DISCO / VIAIR OBA
Rear CV Driveshaft / Rear Detroit Locker / Front Aussie
Teraflex Sleeves / Gussets / Nitro Chromoly Axles
dmhines is offline
post #5 of 24 Old 07-02-2010, 09:49 AM Thread Starter
Thanks. Is there anything under the hood I could use?.
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #6 of 24 Old 07-02-2010, 02:23 PM
dmhines's Avatar
You need something inside since that is where your switch will be ...
dmhines is offline
post #7 of 24 Old 07-02-2010, 03:13 PM Thread Starter
I have them wired up and they work fine but I need to find another power from the relay so when I turn the jeep off they shut off also. I just have them wired up so they are on all the time and still go off with the switch but need them to go off with the ignition of the jeep also in case I forget to turn off the switch and it drains the battery. So I have both the relay and the power to the switch going straight to the battery.
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #8 of 24 Old 07-09-2010, 09:10 PM
prazbotta's Avatar
Sounds like you should wire it off the low beam wire to one of the headlights.
If memory serves it's the brown/white wire going to the lights.
prazbotta is offline
post #9 of 24 Old 07-09-2010, 10:09 PM
.:eMETAL:.'s Avatar
you're going to forget to turn off bright ass fog lights???
i understand the reasoning but again ^^^
IMO tapping them into the low beam sucks... i like having the versatility of being able to turn them on with the highs too.
.:eMETAL:. is offline
post #10 of 24 Old 07-09-2010, 11:52 PM
prazbotta's Avatar
I agree. I thought of that after I posted. In PA, you can't run fogs with highs on-road. I am still admittedly new to off-road 'rules', and this is how we learn.
post #11 of 24 Old 07-10-2010, 05:43 AM Thread Starter
I guess I am the only one. I run mine all the time. I jump out of the jeep and forget to turn them off and hit the switch. You already know the stock head lights sucks and you almost need other light. I run them with my High beams all the time on back roads. If they would turn off with the key I would not have to worry about it.
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #12 of 24 Old 07-10-2010, 05:57 AM
gold knight's Avatar
Sounds like post's 4 & 6 contain the best answer then. A couple feet from trigger wire to switch, then switch to relay = win
gold knight is offline
post #13 of 24 Old 07-10-2010, 07:01 AM Thread Starter
No I am looking some where under the hood. I have them all hooked up fine. I need a hot wire that turns off with the key. The relay is under the hood so it would be easy just to find a wire under there so I would not have to run any longer wire anywhere. I really don't want to hook to the headlight wires because they suck already.
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #14 of 24 Old 07-10-2010, 08:07 AM
.:eMETAL:.'s Avatar
ok... here's a few ideas but not sure if they're legit.
windshield wipers or windshield sprayer? those should be activated by the ignition.
post #15 of 24 Old 07-10-2010, 08:09 AM
Oh sorry I think I see what you're saying now. You have no switch, you just want to have them come on any time the Jeep is on?
I'm sure someone knows.....paging tkob
post #16 of 24 Old 07-10-2010, 09:48 AM Thread Starter
No thats okay I think I am the one confusing people. I have them wired to a switch straight to the battery the power to the relay is also straight to the battery. On/Off switch so they work with the high and low beams on. What I need is a power for the relay so that when I turn the key off in the jeep they go off. So even when I leave them on and forget about hitting the switch to turn them off they will go off when I shut off the jeep.
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #17 of 24 Old 07-10-2010, 09:58 AM
.:eMETAL:.'s Avatar
i understand what you're looking to do...
wouldn't this work?
post #18 of 24 Old 07-10-2010, 01:26 PM Thread Starter
wouldn't this work?
Yes that would but I do not know the colors of the wire?. Screw it I am going to duct tape two flashlights by the door so I can turn them on and off. lol
I need to do it the old fashion way and get out the hot light detector. I thought someone would of done this already and found a hot wire that goes off with the ignition. Thanks for all the help. I owe you a
Rusty's 3.25 coils
MBRP light bar
Rugged Ridge wheels
cvjoint is offline
post #19 of 24 Old 07-10-2010, 01:30 PM
TheGeneral's Avatar
damn, I am looking for the same thing, a hot wire under the hood for my dual battery setup. No answer eh?? Hrmm...
TheGeneral is offline
post #20 of 24 Old 01-09-2011, 12:39 PM
wouldn't it be better to just take your power wire for your switch that is now hooked to the battery and connect it to the pink/white wire under the steering? That is an ignition power source. If you turn off the jeep and forget to turn off the switch the lights will still go off like you want.
Doug
Valparaiso, IN
2007 Steel Blue X Unlimited
Rubi D44 up front with chromo shafts, riddler cover, and CTM u-joints
4" Frankenlift
black steel wheels
35" AT's
Rock Hard bumper and tire carrier
Nate's 4x4 frnt winch bumper
(custom chopped into a stubby)
Rubi rails
Rock Hard skids
KC 8" driving lights
KC 6" driving lights on KC windshield mounts
Tuffy console insert
mr_natural78 is offline
post #21 of 24 Old 01-11-2011, 11:48 AM
leman's Avatar
this
you want to keep the hot wire on the relay going strait to the battery.
1) snip the hot wire going into the switch at the battery.
2) pull wire through firewall
3) trim wire to length for the pink/white wire under the steering column.
4) splice into said wire
5) drink till dark
6) test lights
2008 steel blue sahara
with some doo-dads
leman is offline
post #22 of 24 Old 01-11-2011, 12:25 PM
The Clam's Avatar
I know you already have a switch, but I tapped into the parking lights to trigger my fog light relay (column switch). Ignition based...kinda, it beeps at you anyway, and works with high and low beams.
Just throwing it out there.
~ Clam
The Clam is offline
post #23 of 24 Old 01-11-2011, 03:36 PM
JQJK's Avatar
I just installed four lights on my 08 JK and this is how I got my lights to turn off with the switch. I tapped into (I think M7 in the fuse box next to the battery, check to make sure though) the power outlet that turns on and off with the key switch. The supply wire to the switch will go to this fuse with a "add a fuse". You can get this at Auto Zone for about 8 bucks I think.
The fuse you will be tapping into is a micro fuse so be sure to get the right "add a fuse". The power outlet takes a 20 amp micro fuse, just purchase another 20 amp micro fuse and this should get you what you want since you already have the wire to the switch ran through your firewall. The switch does not take much draw to use so it shouldnt be a problem in respect to having to much on one fuse.
I am pretty retarted when it comes to wiring so I have to give props to DancingDan for helping me. If I can put the link up I will post where I got the most help in wiring from DD.
https://jkowners.com/forum/showthread.php?t=25198
JQJK is offline
post #24 of 24 Old 01-16-2011, 08:45 AM
Heh, I see my work here is already done
That I went through the M7 - Ign/On slot in the fuse box is prolly something I could add to that thar write up...
Dancin Dan is offline
