2016 JKU rear wiring harness question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 04-22-2016, 04:51 PM Thread Starter
mozzer502's Avatar
Hi
at the rear right side, if you remove the plastic paneling you'll expose the wires that come from the tail gate and enter the main body.
This harness twists a little, two wires separate off and disappear up the roll bar - presumably for the interior light - and there's a multi-wire harness connector.
Mine is unplugged. The plug and the socket are just lying there next to each other not plugged in. Everything seems to work. I did not unplug it, though the shop may have when they added central locking.
anyone know that this connector is for?
mozzer502 is offline
post #2 of 6 Old 04-25-2016, 11:26 AM
Not sure if it is the same on 2016 (because the sub is in a different location) but on the 2014 and older I believe those are the Sub, and rear power outlet plugs.
PYAGID is offline
post #3 of 6 Old 04-25-2016, 11:30 AM Thread Starter
mozzer502's Avatar
thank you
post #4 of 6 Old 07-05-2016, 12:26 PM
I just found this plug on mine too, although I only see one plug, does anyone know where I can get a diagram for what each wire is? thinking maybe I can use the wires to hook up my rear back up
camera
swampjeep is offline
post #5 of 6 Old 07-06-2016, 02:09 PM
On my '15 sport, there's no power to either of the plugs. I found that they run all the way to the plug on the passenger side under the glove box, but are not included in the harness from that plug to the fuse box. I installed a rear power point, which is how I found this out.
rc31080 is offline
post #6 of 6 Old 07-16-2016, 09:29 AM
o, must be different then my plug, i tested the connections and one spot in my plug has live power.
