Mopar Connectors - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 06-25-2010, 07:58 AM Thread Starter
chevyjeep's Avatar
Mopar Connectors
The Dealer said they had to replace my whole wire harness for a loose / broken connector. Searched the web and found this web site. Hope it helps someone else also. http://dto.vftis.com/mopar/disclaimer.asp
2007 Jk Rubicon
1952 M38A1
chevyjeep is offline
post #2 of 3 Old 06-25-2010, 08:05 AM
owtdorz's Avatar
That is the same thing the dealer has.
If the dealer knows what they are doing they use it.
Some connectors are not serviced and are only serviced with the harness.
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #3 of 3 Old 06-25-2010, 09:27 AM
Which connector?
Just curious, but which connector was it? The power wire to my Infinity amp was loose, and the amp kept cutting out until I put Goop on the back of the connector to stabilize the connection. Thanks.
bthibodeaux is offline
