ORO Light Install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 03-08-2016, 05:39 AM Thread Starter
Okieveg's Avatar
ORO Light Install
I'll start by saying I've read multiple installs for this on JKO, but none addressed my questions:
I have a Teraflex HD hinged carrier with stock 3rd brake light. I would like to install the ORO in it's place, but maintain the factory connectors in off chance I put it back to stock for whatever reason.
Would this be what I would use: http://www.quadratec.com/products/55...FQmQaQodhqEBLg
Or does someone have a better suggestion?
Thanks in advance!
Okieveg is offline
post #2 of 3 Old 03-08-2016, 08:13 AM
The connectors you linked to are for the taillights. They won't work for the 3rd brake light connector.
I'm in the process of tracking down exactly what connector FCA uses for the 3rd brake light. I have a drawing of it, but no idea if it's a Tyco, Deutsch, AMP, etc.
Chase
2013 Billet Silver JKU Sport S, 6-Speed, TF Leveling Kit, Spidertrax 1.5" Spacers, 285/70R17 Firestone Destination M/Ts on OEM Sport wheels.
COBrien is offline
post #3 of 3 Old 03-08-2016, 01:45 PM
pvanfab.com
pvanweelden's Avatar
just leave enough wire on the factory plug, cut it off, save it with the factory light.
Solder/crimp ORO to the 2 factory wires. You have to run an additional wire to the taillight to get the white led's to light up the license plate if you are using that option.
here's some notes from a writeup i did a while back...
JK- adding led 3rd brake light/ license plate to spare tire location
Use the 2 wires from existing 3rd brake light plus you will need to run 1 wire either thru the tailgate or under right rear to the right rear taillight
Factory white/yellow tracer is brake light positive- ORO red wire
Factory black wire is ground- ORO black wire
New wire to taillight white/purple tracer is parking light- ORO green wire
pvanweelden is offline
