New led tail Lightshow are blinking fast - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 02-23-2016, 08:20 AM Thread Starter
Hi,
I just put in some JW Speakter taillights into my 2008 JKU. Since those taillights are in, the blinking is very fast, when I turn on the turn signal, compared to the stock taillights.
Is that a problem, behause the resistance of the led´s is different than the bulb and this causes this behaviour ?
Did anybody else have this problem and maybe has a solution ?
Thanks in advance for your help.
Traviso is offline
post #2 of 21 Old 02-23-2016, 10:08 AM
You should either add resistors to the turn signal wires or simply change the flasher unit to one designed for LEDs.
Tumbleweed44 is offline
post #3 of 21 Old 02-23-2016, 10:30 AM Thread Starter
Ok, thanks for your reply. Is there a led compatible flasher unit available for a 2008 JKU ?
Traviso is offline
post #4 of 21 Old 02-23-2016, 06:16 PM
There is no "flasher unit" for your Jeep, flash function is controlled by the computer... you need resistors (for the $$ of those, you'd think JWS would have built them into the light)
LDK59 is offline
post #5 of 21 Old 02-23-2016, 09:56 PM
keeponjeepinon's Avatar
50 watt, 6 ohm resistors will do the trick. Wire them in series with the turn signal positive and ground. All of the lights on JKs are controlled by the CANbus, it's a computer that controls all of the electrical gadgets in the vehicle. Changing taillights to LEDs with lower draw confuses the system, and it blinks fast because it thinks the light is burned out.
2013 Commando Green JK - Sold
2014 Suzuki DR-Z400SM - 2001 Honda XR100R StockMoto Race Bike
Ohio Mini Roadracing League #201 - University of Akron Formula SAE - Zips Racing
keeponjeepinon is offline
post #6 of 21 Old 02-24-2016, 05:21 AM
PKDailey4's Avatar
I used these. Takes 5 minutes per side to wire up.
http://www.ebay.com/itm/2x-50W-6-ohm...item3f4578612b
POG MO THOIN
PKDailey4 is offline
post #7 of 21 Old 02-24-2016, 05:31 AM
it'll help you to know that the tailights are on separate circuits-unlike traditional ,older non-CANbus Jeeps- just for the knowledge. Here is my source for all things LED ( including the fast-blink resistors)
post #8 of 21 Old 02-24-2016, 05:01 PM
UnlimiDozer's Avatar
I have a friend who just left his flashing fast. Hasn't hurt a thing.
If you do install the resistors, be sure you mount them so they don't get against any of the brake light wiring harness. They'll get hot enough to melt insulation and short out the wiring. (Ask me how I know.)
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #9 of 21 Old 02-24-2016, 10:22 PM Thread Starter
Thanks to all of you. Will try a resistor.
Traviso is offline
post #10 of 21 Old 02-25-2016, 05:03 AM
PKDailey4's Avatar
You need 2. One wired to each tail light
POG MO THOIN
post #11 of 21 Old 02-25-2016, 06:46 AM
^x2 ; that's why I mentioned the tailights being on separate circuits early, fwiw.
post #12 of 21 Old 02-25-2016, 07:15 AM
The resistors need to be wired in parallel with the bulb, between the turn signal/brake wire and ground.
Wiring them in series will cause the turn signal/brake lights to be very dim.
Chase
2013 Billet Silver JKU Sport S, 6-Speed, TF Leveling Kit, Spidertrax 1.5" Spacers, 285/70R17 Firestone Destination M/Ts on OEM Sport wheels.
COBrien is offline
post #13 of 21 Old 02-25-2016, 06:30 PM
07unlimitedx's Avatar
If you bought the J series JW speaker tail lights, it comes with the resistor required to install them.
07unlimitedx is offline
post #14 of 21 Old 02-25-2016, 07:59 PM Thread Starter
I got this ones from Quadratec: 07 JW SPEAKER 279 J LED TAIL LIGHTS JK
There was no resistor included (at least, I did bot find some.)
Traviso is offline
post #15 of 21 Old 02-25-2016, 08:01 PM Thread Starter
Thank you for the info.
Traviso is offline
post #16 of 21 Old 02-25-2016, 08:01 PM Thread Starter
Traviso is offline
post #17 of 21 Old 02-26-2016, 10:01 AM
bass5money's Avatar
That's strange they do not come equipped with em. The new headlights come with anti-flicker built in..plug and play no separate harness needed either. I have seen several posts on these tail lights and no one has mentioned your issue yet. I'd call JW Speaker and ask them.
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
post #18 of 21 Old 02-26-2016, 10:18 AM
Okay, I'm gonna go out on a limb here and ask . . .
Did you check to be sure that your other bulbs are all burning? Would suck if you went to all this trouble and only had a front bulb out.
My Build Thread:
I'm the NRA
JOIN HERE:
post #19 of 21 Old 02-26-2016, 10:32 AM Thread Starter
Good question. But yes, the two front bulbs are new and work fine.
Traviso is offline
post #20 of 21 Old 02-26-2016, 10:47 AM
If you bought these:
http://www.quadratec.com/products/97009_8050_07.htm
They should have come with resistors. Call QT and let them know. Or, maybe a better option, call J.W. Speaker directly -- they might just send you some resistors for free.
Chase
COBrien is offline
post #21 of 21 Old 02-26-2016, 09:37 PM
tgoss's Avatar
+1. I installed these back in November and they came with resistors pre-wired with a nice bracket to clip onto sheet metal.
tgoss is offline
