hooking up fogs into high beams ?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 06-07-2010, 08:38 PM Thread Starter
genzod's Avatar
i already have a set of driving lights on windshield mounts hooked into high beams,wanna add a set of fogs on bumper and put them into high beams as well,can i do this? i didnt do 1st set,so could i get directions on how this is done,wanna use a switch inside the cab of jeep,thanks
2010 DARK CHARCOAL PEARL SAHARA UNLIMITED
2.5 terraflex coil lift,35 " kuhmo mud terrains,
17 x 9 black v-tec raptors,aev snorkel with raised
breathers, r.r xhd winch bumper w end caps, r.r
8500 series winch, stinger,bush wacker flat fender flares, piaa 540 lights w mopar
windshield brackets,r.r. sill gaurds,light gaurds,seat
covers,floor mats,ect ,ect, ect
genzod is offline
post #2 of 5 Old 06-08-2010, 08:43 AM
TrailDuty.com
PhilD's Avatar
Just trigger a relay from the hi beam circuit. You may have to do the diode/capacitor fix if the lights pulse or dim.
PhilD is offline
post #3 of 5 Old 06-08-2010, 09:47 AM
Mine are hooked up this way, when I get home i'll dig up my wiring diagram and tell you the wires that I used.
I did use a relay but did not need a cap and diode, the actual fog light set up stock is better than the headlights, when I was running all HID stuff up front there were no issues fog wise, headlights needed cap and diode trick.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #4 of 5 Old 06-08-2010, 09:53 AM
2008 JK 4Dr Rubicon
Stone white
Painted hard top
Teraflex 3" lift
rob4607 is offline
post #5 of 5 Old 06-16-2010, 07:28 AM
prazbotta's Avatar
Just did mine
Just installed my driving lights yesterday, so it's still fresh.
My kit came with all the wiring, fuses and switches I needed, but if yours doesn't, it's still pretty easy.
Just need a lead from the positive side of the battery to the relay (May want to put a 25amp inline fuse here), a lead from the high beam wire to a switch in the cab (2amp inline fuse), then back out to the relay. And a ground lead from the relay to bare metal under the hood, along with grounds for the lamps themselves.
My high beam wire was the white/slate wire to the head light harness.
Just a though, but wouldn't you want your fogs to be on with your low beams? Pretty sure that is the white/brown wire in the harness. either way I guess.
prazbotta is offline
