Need to display odometer with cluster removed from vehicle - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 01-21-2016, 01:53 PM Thread Starter
All - have a 2008 Wrangler cluster that I need the mileage on but don't currently have a vehicle to plug it in to. Don't ask...anyway, I tried simply piping 12V and ground to it and that doesn't get it. Looking at the wiring diagram, it seems to me that there's much complexity there, ie, PCM, TIPM, BCMs, CAN C bus, etc. Am I SOL or is there a way to trick this cluster into giving up its innermost secrets? Is the mileage even stored there? Any help appreciated,
MT
Mealticket is offline
post #2 of 3 Old 01-22-2016, 04:31 AM
block's Avatar
im guessing you are going to need to find a jk local to plug it into to get the info. easy swap... i know the milage is saved on the cluster but i believe it is also saved some place else on the jk... good luck .
block is offline
post #3 of 3 Old 01-23-2016, 08:22 AM Thread Starter
Thanks, block. Yeah, I'm thinking you're right. Time for me to cozy up to some Jeepers,
MT
