No electrical power to entire jeep..HELP!!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 05-31-2010, 03:10 PM Thread Starter
I was just out doing some test wheeling on a new lift. Had to winch out of a spot and was in the jeep giving extra rev while I was getting out. I was out of the jeep getting the winch line in and when I got back in the jeep I noticed that the engine had died and the clock had reset.
No problem restarting the jeep...did some more wheeling and then went home. Jeep sat in driveway for about 15 minutes. Went back outside and now I have not power to anything. No lights, dash, nothing happens when I put the key in. Put superchips flashpaq on and nothing happens, no recognition of the connection of power to the flashpaq.
Tested the battery and it is showing 13V and all connections are good. I have a 2009 Unlimited X 4 door with 3" black diamond lift, Recon 10,500 winch, Lower control arms, adjustable front track bar, skid row skid plate, aev nth degree rear slider, smittybilt rock sliders, smittybilt src rear bumper with tire carrier, and rugged ridge front bumper.
I need to go to work and don't have a voltage meter to figure out which relay may be out. Any ideas?
jeffheadley is offline
post #2 of 9 Old 05-31-2010, 04:44 PM Thread Starter
Tried disconnecting battery
Tried disconnecting battery and also tried replacing the 24A CB1 fuse / Ign Off fuse with no luck. An ideas out there?
post #3 of 9 Old 05-31-2010, 04:51 PM
SONIC's Avatar
How do you know your battery is at 13 volts if you dont have a voltmeter? LOL
I would disconect the winch, and try again
-Doc Holiday
SONIC is offline
post #4 of 9 Old 05-31-2010, 04:59 PM Thread Starter
I have a fancy battery charger that checks voltage. Good question though. I have already disconnected the winch as well.
post #5 of 9 Old 05-31-2010, 05:32 PM Thread Starter
Being towed to the dealer...fingers crossed
Well, I have a superchips Flashpaq 87 octane program on the Jeep and it just got towed to dealership under warranty. Let's cross our fingers and hope for the best as far as them not blaming my mods.
post #6 of 9 Old 06-07-2010, 01:30 PM Thread Starter
Re: No electrical power to entire jeep..HELP!!!!
okay...got the jeep back here's the deal. I fried the Front control module because I tried to be fancy and wire in a quick disconnect between the battery and winch. Don't worry, I am now fully aware of how this was totally unnecessary.
I did a poor job if soldering one of my connections and it cake loose. The short caused a power spike which fed back to the control module.
This was not under warranty and the dealership gladly tool $900 from me to fix it. $280 for the part and the rest was for diagnostics and labor.
Retired my winch directly now without the disconnect to ensure a solid connection. Lesson learned!
Sent from my ADR6300 using Tapatalk
post #7 of 9 Old 06-12-2010, 12:38 AM
Glad that you got it back on its feet! I was at a loss on this one.
post #8 of 9 Old 06-12-2010, 06:58 PM
Ouch!
scene: Agaudo smashes cockroach to provoke ventura
Agaudo: Homicide!, ventura how you gonna solve that one?
Ventura: Good question Agaudo,first I'd establish a motive..in this case the killer saw the size of the bugs dick and became insanely jealous!
jkjones is offline
post #9 of 9 Old 06-12-2010, 07:14 PM
tkob1060's Avatar
damn 9 hours or so of labor? that seems pretty damn extreme
glad you got it fixed though
tkob1060 is offline
