What is this for? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 12-14-2015, 02:54 PM Thread Starter
08JKUR33's Avatar
What is this for?
First off I have an 08 Inlimited Rubi and this is a plug in my grill that Leeds to nothing. Has a terminating end on it. Anyone know what it's for? Towing?
Also what is this guy on the inside of the grill on the driver side?
08JKUR33 is offline
post #2 of 10 Old 12-14-2015, 03:34 PM
Deepwater's Avatar
The thingy in the last picture is the outside air temperature sensor. Normally clips on behind the grill. Engine computer uses it to make engine decision, also displays in the instrument panel. Mine broke off too. Not sure what the other is. My 08 Rubi doesn't seem to have one.
We've got em surrounded now boys!: Custer, 1876
Deepwater is offline
post #3 of 10 Old 12-14-2015, 03:38 PM
If you follow the wiring harness on the first connector back, where does it go?
How many wires, and what colors?
Chase
2013 Billet Silver JKU Sport S, 6-Speed, TF Leveling Kit, Spidertrax 1.5" Spacers, 285/70R17 Firestone Destination M/Ts on OEM Sport wheels.
COBrien is offline
post #4 of 10 Old 12-14-2015, 05:55 PM Thread Starter
08JKUR33's Avatar
The colors are 2x black/ red/ yellow and green.
Then fallowing the waire harness back it goes under the battery box and into the cab at the passenger side here.
Then I kind of lose it but think it goes into this plug.
08JKUR33 is offline
post #5 of 10 Old 12-18-2015, 08:31 AM Thread Starter
08JKUR33's Avatar
Bump.... Anyone have any idea?
08JKUR33 is offline
post #6 of 10 Old 12-18-2015, 09:17 AM
Guruman's Avatar
Connector for the e-disco swaybar?
_
Guruman is offline
post #7 of 10 Old 12-18-2015, 09:29 AM
JoeVacs's Avatar
I just looked at the connection of my e-sway bar disconnect. The plug looks bigger than what you show there but I didn't unplug it to see. It is the only wire loom in that area on mine though so I would guess that is what it's for.
2010JKU rubicon, 4'' lift, Currie arms, Synergy ball joints, gussets, and sleeves,Currie high steer and track bar, 40" Procomp MT2 tires, Pro Comp wheels, 5:13 gears, Bilstein 5100 shocks, Tom Woods shaft, Warn Powerplant front, Warn VR8000 rear. Masterpull synthetic lines
JoeVacs is offline
post #8 of 10 Old 12-18-2015, 05:07 PM
LoneJK's Avatar
Same here. Super glued that little sucker to the bar
"Gremlin"
LoneJK is offline
post #9 of 10 Old 12-18-2015, 06:17 PM
apply power to either the red or yellow or green and ground the black and check the tail lights. possible lighting hook up for towing...
jklarry09 is offline
post #10 of 10 Old 12-19-2015, 05:46 AM Thread Starter
08JKUR33's Avatar
Good idea I will try that when I get home from work.
I looked at the e-disco again and that's all hooked up. Had me worried at first lol
08JKUR33 is offline
