Major Driving Light Flicker - Please Help!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 11-07-2015, 08:13 AM Thread Starter
Hi! I could really use some help! I just finished installing Quadratec's stealth LED headlights and fogs and put on an Off Camber light bar with a set of Quadratec 6" round LED lights to be used as driving lights. The headlights and fogs came with harnesses (and anti-flicker modules for the headlights) and work great! The problem is with the driving lights.
The driving lights came with a harness which included a relay. I installed a Rugged Ridge A-pillar switch on the trigger circuit of the relay. I tied into the high beam wire on the passenger side AFTER the anti-flicker module and ran that through the switch and back to the trigger on the relay. When the switch is on, turning on the brights triggers the relay, sending power from the batter to the driving lights. All of that seems to work fine; however, with the engine running, the driving lights flicker REALLY badly and I can hear the relay chattering from inside the vehicle (it's in the engine compartment on the firewall).
I had hoped that by tying onto the high beam wire after the anti-flicker module that I might get a more stable voltage to trigger the relay. Unfortunately, that didn't work. I'm relatively green when it comes to electronics and I really don't know what to do to solve this. Can anyone help?
Thank you so much!
Paw Power is offline
