Running wires through the firewall - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 11-06-2015, 09:43 PM Thread Starter
On my '15 Wrangler I want to run some wires from the engine compartment into the cabin. A cursory inspection of the firewall from the engine compartment, as well as a quick look up into the driver's and passenger's foot well made it evident that this is not a 4-cylinder CJ where you can just put a drill bit into any spot in the fire wall.
Is there a place that is most conducive to running 5 or six wires from the engine bay into the cabin?
donrolandofurioso is offline
post #2 of 9 Old 11-07-2015, 01:55 AM
Landoom's Avatar
If you haven't searched, you may want to try that. I recall reading a post showing some picture of a hole in the firewall or a great place to drill one behind the glove box. It brings you out right by the battery. I have a 2007 and just went through a hole i made in an existing grommet on the driver side.
If it ain't broke, don't fix it. If you don't like it, go break it!
'07 JKRU
3.5" RK X-Factor Lift on 37x12.5x17 MTR-K's wrapped around AEV Pintler Wheels
Landoom is offline
post #3 of 9 Old 11-07-2015, 05:34 AM
I know on the 07 - 11 there is a hole on each side between the door and the end of the dash. You will have to take the dash trim piece off on the ends and you can see it full of foam insulation. The hole comes out under the cowl. Use a metal coat hangar and fish your wires through it.
post #4 of 9 Old 11-07-2015, 08:31 AM
kkuntz01's Avatar
^^^^This
I'm told there is supposed to be an existing rubber grommet on the passenger side you can go through for your with your wires but your have to pull your battery and battery try to access it.
Myself I've been running any of my wires through the grommet/hole in the upper left hand corner of the firewall near the master cylinder. It's where the factory runs the hose to the rear of the Jeep for the washer solvent and the same spot where sPod runs their harness through for the switch panel. Just be careful not to perforate the hose when you puncture the grommet. Don't ask me how I know.
I know some guys will run wiring the hole on the outside of the fender right under the A-pillar. I had done that too initially until I was laughed at for the half ass hack job I did with the wiring. I subsequently re-routed the wiring through the same hole my sPod harness is run through.
Also not sure how anal you are about clean wiring. Something I stumbled on that has made my wiring jobs much cleaner and easier to run through the vehicle.
PET Expandable Braided Sleeving
kkuntz01 is offline
post #5 of 9 Old 11-07-2015, 10:21 AM
Ronson's Avatar
Did this on my 2012 to run the fat wires for my ARB compressor under the seat. It has 3... if I had to guess 0 guage wires and one or two smaller ones. It was a Bitch but it fit.
Did the same on the drivers side for my CB and the lighted switch for the compressor.
Ronson is offline
post #6 of 9 Old 11-07-2015, 12:40 PM
ndtguy's Avatar
It applied for my 2014 also.
NDTguy
2017 JKU Sport S
ndtguy is offline
post #7 of 9 Old 11-07-2015, 08:49 PM
bigworm36's Avatar
Should be the same for the 2015
bigworm36 is offline
post #8 of 9 Old 11-12-2015, 05:59 PM
You can run wires through the firewall on the passenger side. I simply removed my glove box and went through the firewall...and I didn't have to pull my battery to do it (someone mentioned that above).
Since I didn't have a wire coat hanger, I cut the swatter portion of a fly swatter off and used that metal to fish the lines. Oh, and I found it easier to fish the lines from the engine compartment towards the interior. Just look up behind the passenger fender liner.
IndyRubicon is offline
post #9 of 9 Old 11-12-2015, 08:59 PM
I ran amp wiring right through the factory grommet. I used a large tie wrap with a bit of silicone grease to ease it through. The tie wrap is basically the size of one they use on duct work and works great for fishing wires as it won't damage. In the past I used tie wire, but that can scratch and when you bend a loop on the end, it can get stuck from time to time.
rejeep13 is offline
