new CB and scanner mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 05-12-2010, 12:30 AM Thread Starter
venom's Avatar
I've had a single mount over the mirror for awhile, and been swapping back n forth between my Bearcat BC350C scanner and my CB on the same mount.
Finally decided to make a mount and hook 'em both up.
used one of these around the RH front bar...
added a piece of angle iron and came up with this...
Name:  cb mount1.jpg
ended up moving both of them up nice and high, I can actually see the whole mirror now - not that I can see anything in it other than spare tire, but its nice to have them tucked up and away.
Also added one of these for massive PA system fun - darn thing is so big, ended up mounting it over the rear axle.
Originally Posted by My Wife
venom is offline
post #2 of 14 Old 05-12-2010, 03:36 AM
Loki646's Avatar
Sweet setup, V!
Loki646 is offline
post #3 of 14 Old 05-12-2010, 04:35 AM
Now that's a good idea. Have to remember this one.
Ron
"Some people spend an entire lifetime wondering if they made a difference in the world.
But the Marines don't have that problem." ..... Ronald Reagan
wanderingtrail is offline
post #4 of 14 Old 05-12-2010, 05:22 AM
BigMike's Avatar
Breaker Breaker good buddy
, Granite,
BigMike is offline
post #5 of 14 Old 05-12-2010, 09:39 AM
Get on the PA and yell at people to get of your way.. MAD JEEPER COMING THROUGH!!!!
Vote - Bacon for 2012!!!
benmar2000 is offline
post #6 of 14 Old 05-12-2010, 01:11 PM
v10kingsnake's Avatar
I hope you stay clear of the deep water. That horn would be KO'd in short order on my jeep. Nice mount though.
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #7 of 14 Old 05-12-2010, 02:09 PM
ONLYSUPER's Avatar
This is what i want to use to mount my CB. I will make it fit either on the first or second compartment. I will be able to just make it work so it will be out of sight when not in use.
JKOutcast Member
ONLYSUPER is offline
post #8 of 14 Old 05-12-2010, 04:12 PM Thread Starter
venom's Avatar
its a waterproof horn for mounting outside so it should be ok when it gets dunked - my snorkel aint for looks!
It's mounted so it will drain water out.
yeah but it don't do much to shore up the roll cage
I just added molle covers to my RH section so I'm getting some storage out of it too.
venom is offline
post #9 of 14 Old 05-12-2010, 04:23 PM
ONLYSUPER's Avatar
Got you, i just don't need a roll cage for what i do. I will if i get to move to Cali or Colorado.
JKOutcast Member
post #10 of 14 Old 05-12-2010, 09:32 PM
LSUjeepguy's Avatar
Nice! Real nice, sir! Perfect fit between the sun visors...
____________________
Quote: Originally Posted by aaronkushner BBrish.....im not the a Mets fan like you....who the retard now? lmao
LSUjeepguy is offline
post #11 of 14 Old 06-09-2010, 05:41 PM
Mike's Avatar
Attachment 19526
I wish I could see the mount better, I am really wanting to do this but can't figure out a mount for the foothold. I am thinking about just screwing into the plactic shrould above the mirror. I have a full size CB but I think it would work.
Mike is offline
post #12 of 14 Old 06-10-2010, 07:53 PM
bluerubicon08's Avatar
I screwed through the plastic into the metal on the windshield frame using some self-drilling screws. Works like a charm, and I'm running a full size CB
If you're gonna be fucking weird, own it.
~SoCo
______
bluerubicon08 is offline
post #13 of 14 Old 06-10-2010, 09:45 PM
TheBeatenPath's Avatar
GENIOUS
i couldnt find a gif of the guinness commercial
TheBeatenPath is offline
post #14 of 14 Old 06-11-2010, 08:24 PM
RODICON's Avatar
Sweet setup!
2014 Rubicon on the build!
RODICON is offline
