Cooling Fan Replacement - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 05-10-2010, 04:58 PM Thread Starter
SASQUATCH's Avatar
Yes I searched, advanced for titles on the Title. Looks pretty straigthforward just glancing under the hood, mines finally shot, new one will be here tomorrow. I was able to order just the motor and I'll assume the motor shaft is keyed with a couple set screws.
Anyone have any tips or is it just a quick and easy plug-n-play? Oh yeah I realize some are doing the SPAL, but I'm ok with an OEM replacement for now.
Thanks in advance.
SASQUATCH is offline
post #2 of 7 Old 05-10-2010, 05:25 PM
tkob1060's Avatar
take the plastic cover off the top of the radiator
remove the over flow tank and place it between the engine and master brake cylinder(it stands up there perfectly)
remove 8mm bolts at top of each side of the shroud(bottom of shroud sits in 2 v-grooves)
unplug the electrical connector at top of shroud
lift shroud up, turn slightly in on passenger side and lift out
13mm nut reverse thread removes the fan blades
unplug the electrical connector at the fan motor
3 10mm bolts removes motor from shroud
thats it, very simple, shouldnt take more then 15 minutes
tkob1060 is offline
post #3 of 7 Old 05-10-2010, 07:35 PM Thread Starter
SASQUATCH's Avatar
Thanks TK, my replacement motor does not include the fan, isit as I described? Keyed with set screws on motorcshaft? Again thanks!
post #4 of 7 Old 05-10-2010, 08:56 PM
tkob1060's Avatar
its just the 13mm nut holding the fan blades onto the motor, they are both keyed to lock into each other, here is photos you can see the little nubs that drop into the grooves on the motor
tkob1060 is offline
post #5 of 7 Old 05-10-2010, 09:11 PM Thread Starter
SASQUATCH's Avatar
Thanks a million!
post #6 of 7 Old 05-16-2010, 09:16 PM Thread Starter
SASQUATCH's Avatar
Thanks again TK, forgot to followup and state it literally 15 mins as you said, works like a charm now!
post #7 of 7 Old 05-16-2010, 09:26 PM
Somehow I knew you would be the first post.
How many have you gone through now? 9 or 10 I think. How is that waterproof one holding up?
Fnord5 is offline
