Pillar light mounts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 09-13-2015, 03:41 PM Thread Starter
misiek's Avatar
Pillar light mounts
So i wanted to change out my pillar lights for a dual setup but im not sure i like the stacked looked.... i was wondering if they make a pillar light mount that would hold two rigid dullys side by side instead of over under... tried to google a bunch of different ways but i keep getting the original over and under or side by side utvs
misiek is offline
post #2 of 3 Old 09-13-2015, 04:22 PM
sprockwell's Avatar
KC makes two different A-pillar mounts - one mounts in the typical position and the other using the outboard bolts in front of the rear view mirrors. You could use both to get the effect. FWIW I have the outboard mounts with traditional halogen lights and there's noticeable wind noise from the setup.
sprockwell is offline
post #3 of 3 Old 09-13-2015, 05:37 PM
i used the standard mount for one, and the factory hinge cover bolt for the second. bad pic, but it's all i have saved online to share
2012 Black JKU , 2.5 RockKrawler lift, 285/75-17 nitto terra's, Custom AtoZ sliders, AtoZ bumper with Quadratec I9500 winch..
jkwirfel is offline
