No fog lights to fogs, what would you do - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 09-06-2015, 01:31 PM Thread Starter
Alright..my 07 x has never had them... I got a freebie rubicon bumper to replace my trashed one, I need to stubby it and get some lighting.. Budget minded (with in reason) what lighting would you put in the holes. I need everything down to the switch, I'm happy to run these manually through their own switch so I can do with or with out headlights,hi/lo. Also I'm thinking Amber since for some reason I recall seeing the amber is better with snow,fog, shit weather in general but that is likely not the case so I'll listen to you guys.... I through about hacking it and running a light bar centered in their too...it's a free bumper so I'm fine with getting creative if I get the direction!
fearfact is offline
post #2 of 6 Old 09-06-2015, 02:32 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Bang for the buck, the Morimoto Type M LED Fogs are the way to go. 170 bucks for a set, direct bolt in, and can be wired without the factory harness because there is a 9006 plug on it which is pretty universal.
http://www.theretrofitsource.com/com...l#.Veyiuinn_qA
JKCTAZ is offline
post #3 of 6 Old 09-07-2015, 02:12 AM
Mason's Avatar
There are companies that make a bracket to secure any LED pod to the fog lights. I have a set of rigid D2s in mine and use them as my high beams.
Mason is offline
post #4 of 6 Old 09-07-2015, 04:25 AM
The real best bang for the buck (only $40 for the pair) is to buy factory take off fogs from Rubitux.
http://www.rubitrux.com/jeep-take-off-lighting.html
IndyJLH is offline
post #5 of 6 Old 09-07-2015, 03:52 PM Thread Starter
I saw the bracket options and figured that is the likely route with some d2s or knockoffs...now how about idiot proof wiring and switches..I would rather throw a switch in one of the empty slots by the esc kill button if I find one...eventually locker switches will take the remaining 2 slots
fearfact is offline
post #6 of 6 Old 09-08-2015, 10:08 PM
misiek's Avatar
Amazon sells an idiot proof wiring kit for under $20.... comes with switches, fuses, relays, connectors and a bunch of wire all pre connected
misiek is offline
