Wiring ORO License plate Light with Poison Spyder Tranp Stamp? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 09-01-2015, 02:38 PM Thread Starter
JNWFJ's Avatar
How is this done? Is there a write up? I've looked and not found a thread that explains how to get it wired with it being hidden behind the poison Spyder tramp stamp, thanks in advance
'12 JKU Rubicon | RK 2.5" Stock Mod w/ .5" TeraFlex Spacers | Bilsteins 5100s | 4.10s | AEV Pintlers | 35x12.5R17 Mickey Thompson Baja ATZs | Rancho Drop Brackets | Superchips FlashPAQ
JNWFJ is offline
post #2 of 8 Old 09-03-2015, 06:42 AM
you did not sleep during the lessons the master was teaching during Google-Fu class, did you? If you simply google your subject of this thread you can find this link under the 'videos' header criteria, mate!
post #3 of 8 Old 09-03-2015, 04:35 PM Thread Starter
JNWFJ's Avatar
Still don't see it, I see a video about a poison Spyder led harness and tramp stamp installation video, I don't need to know how to install a tramp stamp just a wiring diagram to install the ORO PlateLite and hookup the actual license plate and 3rd brake light
JNWFJ is offline
post #4 of 8 Old 09-03-2015, 06:05 PM
JKO Dickhead
Asmmns's Avatar
I can probably did up some pics or go pull off some panels to show you..
I do recall it being a bit of a fishing expedition because I wanted it completely hidden. I drilled a hole in the tailgate for the wire just behind the tag light, which puts the wire in between the two panels. I was able to fish it out after removing the plastic panel on the inside, guided it through the sleeve near the hinge and wired it up.
Super neat and you cant even see the wire
__________________
CURE SMA !
Asmmns is offline
post #5 of 8 Old 09-03-2015, 08:20 PM
I ran my wires through the vent into the tailgate. The license plate light I wired in behind the sub panel. The brake light I tapped in to the right rear brake light wiring. Was a pretty easy job. Good luck
X50ARM is offline
post #6 of 8 Old 09-04-2015, 05:19 AM Thread Starter
JNWFJ's Avatar
I'm fine with fishing it through the vent hole, I just don't know which wires I tap the 3 wires on the ORO PlateLite, you can't use the wires that run behind the long rectangular black pane on the tailgate?
JNWFJ is offline
post #7 of 8 Old 09-04-2015, 10:20 AM
I didn't take any pics, see if this helps: https://www.jkowners.com/forum/showthread.php?t=72496
X50ARM is offline
post #8 of 8 Old 09-04-2015, 12:40 PM
pvanfab.com
pvanweelden's Avatar
JK- adding led 3rd brake light/ license plate to spare tire location
Use the 2 wires from existing 3rd brake light plus you will need to run 1 wire either thru the tailgate or under right rear to the right rear taillight
Factory white/yellow tracer is brake light positive- ORO red wire
Factory black wire is ground- ORO black wire
New wire to taillight white/purple tracer is parking light- ORO green wire
pvanweelden is offline
