HID's for Headlights and Foglights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 05-03-2010, 01:30 PM Thread Starter
Rubicon OIF 09's Avatar
Send a message via AIM to Rubicon OIF 09
I just ordered a 55 watt hi/lo beam 5000k and 35 watt foglight 3000k for my 08 rubicon from DDMTUNING. Anyone currnetly running HID kits experience any problems? Pictures would be appreciated.
2014 Unlimited Rubicon X in Bright White!
3.5 Rock Krawler X factor lift, Truck Light headlights, a couple Rigged Industries light bars and Nitto Mud Grapples 37x13.50R17 on KMC Rockstar II's, Uniden Bearcat CB, RIPP Supercharger, Smitty BUilt 10k wireless winch with synthetic line, LUX Rock Lites, Rancho 9000 shocks, Crawler Concepts front bumper sprayed with Line-X, Grab Bars on the interior, with all Kicker Speakers including the kicker hide away sub in addition to the factory sub
Rubicon OIF 09 is offline
post #2 of 22 Old 05-03-2010, 01:50 PM
ONLYSUPER's Avatar
I got my headlight and fog light kit from vvme.com. they are great so far.
Headlights
http://www.vvme.com/12v-5055w-h132-h...cPath=44_53_48
Fog lights
http://www.vvme.com/12v-5055w-h10-hi...cPath=44_45_26
I also got the error canceller for HID.
http://www.vvme.com/universal-for-al....html?cPath=39
I am happy with how bright these are. No pics so far.
JKOutcast Member
ONLYSUPER is offline
post #3 of 22 Old 05-03-2010, 01:52 PM
ALASHA's Avatar
Headlights
Fog lights
Do you need a cancellor kit for the fog lights or just for the headlights?
ALASHA is offline
post #4 of 22 Old 05-03-2010, 01:53 PM
ONLYSUPER's Avatar
Just the Headlights
JKOutcast Member
post #5 of 22 Old 05-03-2010, 01:56 PM Thread Starter
Crap! The guy asked me if I needed the headlight cancelor kit too. I didn't think chrysler was that advanced! Is that something I should call back and order?
Just the Headlights
post #6 of 22 Old 05-03-2010, 01:58 PM
ONLYSUPER's Avatar
Yes. if not they going to do the blinky thingy.
JKOutcast Member
post #7 of 22 Old 05-03-2010, 01:59 PM Thread Starter
What did you do to your headlights? They look dark? Are they replacements or spray tint?
Just the Headlights
post #8 of 22 Old 05-03-2010, 02:01 PM
ONLYSUPER's Avatar
I removed those and got the OEM ones back on with the HID kit. I had a black out headlight kit but it sucked balls.
JKOutcast Member
post #9 of 22 Old 05-03-2010, 02:08 PM
ONLYSUPER's Avatar
also check this thread with picks and install tips
https://jkowners.com/forum/showthread.php?t=21761
JKOutcast Member
post #10 of 22 Old 05-03-2010, 02:19 PM
You will need the kit to stop the flicker on the headlights or you can but a capacitor and do it yourself. The fogs are a non issue and ug and play no issues, headlights flicker if you don't have the capacitor like I said. Once installed turn the headlight adjusting screw about 3/4's of a turn to lower them so you don't blind everyone and get flashed all the time.
And order a extra high low bulb so you have it cause you can't exactly run to autozone and get them. I finally removed all my hid crap and put in the cebies, much better! The hid warm up was annoying along with messing up radio stations. But it was worth it x100 compared to stock.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #11 of 22 Old 05-03-2010, 02:31 PM Thread Starter
That thread was exactly what I needed. I asked the guy about the error code and he said I would be fine! I'm adding it to my order now. Thanks again for all this. I love preventing headaches!
post #12 of 22 Old 05-03-2010, 03:01 PM
ONLYSUPER's Avatar
Glad it helped.
JKOutcast Member
post #13 of 22 Old 05-05-2010, 09:39 PM
I put the silverstar lamps in the headlights - good upgrade
tried to get them for the fog lamps - was told that they are not available. Quadrateck was no help.
JP
2010 Sahara unlimited
pemberton is offline
post #14 of 22 Old 01-09-2011, 09:35 AM
Grant211's Avatar
Headlights
Fog lights
OLD POST I KNOW -
Question on the FogLights - Why did you go with the 50w/55w HID kit vs. the digitial slim kit, Relay harness HID kit, or standart HID kit?
Link to different kits available - http://www.vvme.com/page.html?chapter=1&id=33
Grant211 is offline
post #15 of 22 Old 01-12-2011, 07:19 AM
Hilldweller's Avatar
How do you define "issues"?
The illegal bootleg rebased HID capsules that you installed have igniters that draw fairly high amperage at start-up. Don't you think this might do something to your stock wiring after a while?
I mean, besides that fact that they're illegal, of course.
There are better H13 bulbs that put out more light and last longer.
The Phillips Xtreme Power is the best direct replacement you can get right now.
Silverstars are merely blue-tinted bulbs that your eyes can't focus on or with. That's why they look brighter. They aren't though; you can't fool a meter as easily as you can fool your eyes.
Safety fast,
Get to know
Hilldweller is offline
post #16 of 22 Old 01-12-2011, 05:29 PM
Send a message via AIM to jocrazy0
My issues with HID lights have been they are TOO bright for normal highway driving. getting them adjusted so they won't be a hazard to other drivers has been a pain and no luck so far (I have mine installed in my CIBIE housings. I may try the originals and see if a different technology improves the pattern).
I had the Silverstars in prior to the HID mainly because the H4 OSRAMs earlier installed failed in 12 months (within a day of each other). The Silverstars are more available (and I still carry two as spares) but the light output is mediocre, not nearly as good as the H4 OSRAMS.
I replaced my fog lamps with 55watt 9005 lights. (I do have relays with diodes and capacitors to switch the circuits for the lights so I have had zero computer issues or flicker). The 9005s go in the same fog lamp mount with a bit of finagling. They are brighter, but I think I prefer something a bit more yellow for fog lamps. (as FOG LAMPS not DRIVING LAMPS which at least half of the other drivers seem to think is so cool.... run with the FOG LAMPS on all the time. What do they not understand about the FOG in "FOG LAMPS"?
2007 Rubicon, Graystone, Auto, Dual, Power, Tow,GENTEX autodim mirror,COOL TECH antenna mount&exhaust,CIBIE,HELLA TPMS,AEM CAI, Fuel Door, Grab Handles,Tuffy,Thule,Olympic,HESCO Supercharger, HID, RR XHD FB w/stinger,DRAKE hoodlatch with locks
1972 C104 Commando - Bone stock
jocrazy0 is offline
post #17 of 22 Old 01-12-2011, 05:52 PM
When our lights are as shitty as they are, do you blame people from running with fogs whenever possible?
2012 Silver JKU Rubicon
5 speed auto, 4.10s
Riptide is offline
post #18 of 22 Old 01-12-2011, 06:00 PM
fourplyn's Avatar
not really, I ran my fogs when I had them because of that exact thing.
I'm sending my stock lenses out very soon to have the TRUE HID ballasts installed instead of this bulb thing you guys are doing.
Will have REAL HID lights with the stock lens. Different rear housing, and it will be a plug and play type of scenario.
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #19 of 22 Old 01-13-2011, 02:52 PM
You mean projector HIDs vs using HIDs in the stock reflector?
5 speed auto, 4.10s
Riptide is offline
post #20 of 22 Old 01-13-2011, 03:20 PM
virtual_mage's Avatar
how about caring for people on the road and not blinding them?Most hid kit should not even be legal.Im so tired here in Fort Mcmurray half of the truck are lifted use HID and are not aim properly....use a proper set of hi quality halogen for your daily drive.
Send a email to that guy he will provide you with a proper kit and wiring for your jeep .
http://www.danielsternlighting.com/t...fog_lamps.html
Winter is coming.
virtual_mage is offline
post #21 of 22 Old 01-13-2011, 05:26 PM
I hear you. That being said, I'm still putting an HID kit in this JK (as I've already purchased it). The next one (either next year, or a 2012) will go with quality halogen lights and fogs with HIDs for auxiliary lighting.
5 speed auto, 4.10s
Riptide is offline
post #22 of 22 Old 01-14-2011, 04:20 PM
But the fogs just provide foreground illumination and actually mess with your distance sight.
Which is fine if you're just going 25 mph. But, if you're on the highway, turn off the fogs. Humans are very poor judges of how they're own vision is performing.
The reason that the new foglight regulations were thrust upon us is because people were using their foglights inappropriately.
Safety fast,
Get to know
