Sirius Reception Problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 04-28-2010, 07:37 PM Thread Starter
Is anyone having recent problems with Factory Sirius reception>
Mine started a few days ago.
It's almost like the antenna wiring may be loose but it also has symptoms of a low transmit signal from the Sirius satellite.
belmoresr is offline
post #2 of 15 Old 04-28-2010, 07:39 PM
Yes, I've got a 2010 Rubi Unlimited that's about three months old and my Sirius reception just starting going in/out too. Not sure what's up.
Bujkeye is offline
post #3 of 15 Old 04-28-2010, 08:12 PM
MaloCS's Avatar
Bad antennas. More then likely they're going bad or there's some sort of interference with rook racks, sport cages, etc...
The OEM head unit uses a standard connector so you could always buy a cheap replacement from Car Toys, Best Buy, etc... and verify the antenna problem. If you go this route you can mount the antenna on the hood cowl for better reception.
And here's a very good antenna from Car Toys made by Terk. Take special note of the connector. This antenna plugs right into the head unit; no splicing or adapters needed.
Those that the beast is looking for...
Listen in awe and you will hear him...
BARK AT THE MOON!
MaloCS is offline
post #4 of 15 Old 04-28-2010, 08:19 PM
Guruman's Avatar
I had similar issues about a year ago. It turns out the antenna cable for the sat was getting pinched behind or on top of the radio unit. I was able to just reposition the wiring, and I have not had the problem since.
It's worth a shot.
_
Guruman is offline
post #5 of 15 Old 04-28-2010, 10:21 PM
I have problems in the winter when I have my ski hauler on my jk. If I load the roof up with skis, I get no reception whatsoever. I'm assuming the metal in the skis block the reception. I'd think if you installed a metal rack on the roof or something like that, you'd have a similar problem. Good luck.
Rotmilky is offline
post #6 of 15 Old 05-02-2010, 10:27 AM
H3ATH3N's Avatar
Do you have a link to this antenna? Does that plug type have a formal name?
I have searched for that specific antenna, and I have come up empty handed.
Life moves pretty fast. You don't stop and look around once in a while, you could miss it.
H3ATH3N is offline
post #7 of 15 Old 05-03-2010, 09:44 AM
MaloCS's Avatar
Sorry but I don't have a direct link. This specific antenna is made by Terk and can be picked up at Car Toys; at least that's where I got mine. It retailed for about $30 and they had it in stock. I've been told that Best Buy and Ultimate Electronics also carry them in stock.
The key, no matter the brand, is the connector that's shown in the photo. Any Sirius antenna should work as long as it has that specific connector. I would print the photo and take it with you for a comparison before buying.
Good luck.
BARK AT THE MOON!
MaloCS is offline
post #8 of 15 Old 05-03-2010, 03:05 PM
Mine quit receiving last week, had a number to call to "subscribe"... I called it to see WTF.. the lady said "oh we have to reactivate your radio every so often".. didn't take very long, but all presets are gone.
The Exim in my wife's Lexus goes dead around the square in our little town.. I blame it on the city's wifi antennas? The Jeep doesn't do it as bad..
cowboy49 is offline
post #9 of 15 Old 05-03-2010, 04:33 PM
Tail Rated's Avatar
...just did the same mod!! After the GOBI rack, I had some reception issues, so new Car Toys antenna and all is good. Drove around in circles.
no more issues. ...although I did get a little dizzy!
2016 JKU
Tail Rated is offline
post #10 of 15 Old 05-03-2010, 04:43 PM
v10kingsnake's Avatar
not sure about you guys but near me a lot of roads are surrounded by trees. in the winter, it is not an issue but as spring hits and leaves are full in the trees, the shade cover blocks the sat signal causing intermittent interruption.
2009 Sahara Unlimited. 5.7L Hemi truck setup. Rock Krawler 5.5 coil over LA. Maxxis Trepador 40's . ATX Rims, XRC front rear and side armor. RROR Crusher corners, RROR flat flares. Warn XD9000i. Prorock 44 with RCV shafts. 5.13 gears, ARB front and rear lockers.
v10kingsnake is offline
post #11 of 15 Old 05-03-2010, 06:49 PM
Dragline's Avatar
x2 - drives me crazy!
08 Rubicon 2DR Red Rock
Dragline is offline
post #12 of 15 Old 05-03-2010, 07:10 PM
H3ATH3N's Avatar
Looks like the plug type is knows as a FAKRA plug. I could not locate that TERK antenna on the car toys site, but their are plenty results on Google.
Here is a link to the TERK antenna MaloCS is referring to, but it's out of stock.
Here is an adapter I located if you don't want to be limited to a particular antenna.
I am looking at going with something like this. 35dB of gain should resolve any reception issues.
H3ATH3N is offline
post #13 of 15 Old 05-06-2010, 07:36 PM Thread Starter
Problem resolved itself
I did nothing and the situation cleared itself up.
I suspect that Sirius had transmitting problems.
thanks for all the help.
post #14 of 15 Old 05-08-2010, 02:47 PM
I had really patchy reception with my stock radio, 100x better soon as I upgraded to my kenwood using the stock antenna .
07' Rubicon Unlimted.
pha-cue is offline
post #15 of 15 Old 05-08-2010, 03:06 PM
Jagrmaister's Avatar
I've had mine since last september, and other than occassionally going out under a bridge, and a couple sporadic lost signals a couple days ago during some heavy storms rolling in, there hasn't been any problems with it.
2010 Jeep Wrangler 2dr Rubicon with a part from everyone...
Jagrmaister is offline
