electric fan kill switch - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 08-13-2015, 06:03 AM Thread Starter
oscar the grouch's Avatar
i do a lot of creek crossings. is there an easy way to kill the fan so i dont KILL the fan?
oscar the grouch is offline
post #2 of 7 Old 08-13-2015, 06:49 AM
Why can't you just run a simple switch that is just on or off. I use one in the starter relay wiring to have a simple kill switch.
DON'T FORGET TO TURN IT BACK ON.
post #3 of 7 Old 08-13-2015, 06:56 AM Thread Starter
thats what i was thinking. maybe on the ground wire. with the canbus BS im hesitant to break any signals in the system.
post #4 of 7 Old 08-14-2015, 06:44 AM
You are only momentarily killing the signal. It should be good.
post #5 of 7 Old 08-14-2015, 06:56 AM
Guruman's Avatar
Is this really an issue? I've dunked a TON of electric fans without killing one. With an electric fan the water slows it down so that it does not contact the radiator. Unlike an engine driven fan, which without a clutch will deform under the restriction of the water and absolutely eat a radiator. I found that out the hard way many years ago.
I've been in the habit of swapping out engine driven fans for electrics just for this reason. I've dunked a bunch of them. Is the JK fan not sealed or something?
_
Guruman is offline
post #6 of 7 Old 08-17-2015, 07:21 AM
The stock fan is not sealed.
post #7 of 7 Old 09-06-2015, 12:57 PM
WarMachine's Avatar
That's a good idea. I killed mine a couple months ago going through a large, deep puddle. Even though I went through slowly enough so that I didn't create enough of a bow wave to get water in the intake and hydrolock my engine, a day or so later I discovered the fan was dead when I was stuck in gridlock on my way home from work.
Even though the replacement fan I installed is sealed and has a lifetime warranty, I think I may still put a kill switch too.
I gotta be me cause everyone else was already taken.
WarMachine is offline
