08 Transmission range sensor wiring diagram - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 07-13-2015, 06:09 PM Thread Starter
Anybody have a 08 trs wiring diagram? I need to see the tracer colors on the range side.
ScottyB07 is offline
post #2 of 9 Old 07-13-2015, 06:53 PM
ronjenx's Avatar
Not sure what you mean by "on the range side".
Do you want the wire colors in the body harness that connects to the transmission, and the corresponding contacts in the sensor?
ronjenx is offline
post #3 of 9 Old 07-13-2015, 07:05 PM Thread Starter
Hey thanks for the responce. I'm referring to the wires only for the range sensor not the temp sensor. I'm looking for wire colors and position. Off the top of your head do you know if the colors change for 07 to 08?
post #4 of 9 Old 07-13-2015, 07:08 PM Thread Starter
Maybe if I cut to the chase it would help. I have a Ls 5.3 and I'm wiring in a prndl controller and the wiring info I have shows two wrong colors.
post #5 of 9 Old 07-13-2015, 07:32 PM
ronjenx's Avatar
I hope this is what you are looking for:
YL/DB = T41, pin 10, contact 1
DG/YL = T42, pin 9, contact 2
DG/DB = T3, pin 8, contact 3
DG/LB = T1, pin 7, contact 4
TRS SWITCH STATES
SLP T42 T41 T3 T1
P....CL...CL...CL..OP
R....CL OP OP OP
N....CL CL OP CL
D....OP OP OP CL
2....OP OP CL OP
1....CL OP CL CL
ronjenx is offline
post #6 of 9 Old 07-13-2015, 07:35 PM Thread Starter
Thank you for the detailed info. Is this for a 08?
post #7 of 9 Old 07-13-2015, 07:39 PM
ronjenx's Avatar
Yes, '08, as specified in your first post.
ronjenx is offline
post #8 of 9 Old 07-14-2015, 04:24 PM Thread Starter
Thanks that told me all I needed. It's working great.
post #9 of 9 Old 07-14-2015, 05:06 PM
ronjenx's Avatar
Glad I could help.
ronjenx is offline
