CB antenna question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 04-18-2010, 10:09 AM Thread Starter
Jimmy2x's Avatar
CB antenna question
I just got my new Wilson Flex antenna and see that it has a little pig tail wire down by the base. What is that for? I understand that the antenna mounting bracket should be grounded but does the antenna also? Thanks.
"A government that is big enough to give you everything you want, is strong enough to take everything that you have." - Thomas Jefferson
Jimmy2x is offline
post #2 of 4 Old 04-18-2010, 10:42 AM
FLLawdog's Avatar
It's a ground wire. I was running SWR's off the freakin' scale, thinking I had everything grounded (had the ring terminal on one of the bolts holding the 3-way mount). After adding some wire and running inside to the big black gat latch (I have a TJ, not sure what the JK's have), I was pulling a 1.1/1.2 across the channels.
Originally Posted by StubEXrube
Once upon a time grown men didn't act like assholes for no reason nor get butt-hurt by complete strangers.
Then the internet was born.
FLLawdog is offline
post #3 of 4 Old 04-18-2010, 10:45 AM
Yes, it's a ground wire. Most folks don't use it. I have the same antenna and I don't use it. My CB works very well.
4x4x4 is offline
post #4 of 4 Old 04-18-2010, 01:51 PM Thread Starter
Jimmy2x's Avatar
Thanks. I appreciate the info guys (gals too)!
Jimmy2x is offline
