AMP HELP - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 04-15-2010, 12:36 AM Thread Starter
2008jkx's Avatar
AMP HELP
HEY! so after 2 hour of setting up my subs and amp i get it all turned on and only the red protection light comes on..
why is this! its a ppi2240 with 2 8 in JB audio subs
2013 rubi axles. 2.5in RK max travel. coast front DS.. rockhard oil pan and tranny skid plate. xrc 8 comp winch mounted on RR XHD
south lake tahoe california.
2008jkx is offline
post #2 of 5 Old 04-15-2010, 01:52 AM
Webhead's Avatar
If you remove the input wires and the wires to the subs, does the protection light still come on?
Is the amp grounded to bare metal?
2010 2-door, Dark Charcoal, 6-speed Rubi
Webhead is offline
post #3 of 5 Old 04-15-2010, 05:14 AM
usmcdoc14's Avatar
ground, did your remote wire touch the ground, is a strand of it touching ground, fuse on AMP blown, disconnect speakers and try again, pull fuse and wait then try again.
usmcdoc14 is offline
post #4 of 5 Old 04-15-2010, 07:14 AM
BeerMonkeY's Avatar
do like they said, if you un hook everything but the power wires and it still does it the amp is prob bad, if you unhook that stuff and it doesnt do it then hook the rca's back up and try it again. if it does it then the rca are prob bad if it doesnt do it then the speaker wires are shorted or the subs are bad
'92 YJ
'13 WK2
BeerMonkeY is offline
post #5 of 5 Old 04-15-2010, 09:10 PM Thread Starter
2008jkx's Avatar
of course it was just the ground... a 240 watt bridged with 2 jl audio 8s sounds pretty good
2008jkx is offline
