Broken Door Locks - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 04-07-2010, 01:36 PM Thread Starter
jason0341's Avatar
Broken Door Locks
So my Drivers side door is no longer locking. Windows roll up and down fine. When i use the key fob or in the inside of the Jeep no luck. Barely moves on the door. Any suggestions ideas? I have repeatedly unplugged and plugged the door back in, still no luck. Anyone know which fuse it might be, how to remove and replace it?
jason0341 is offline
post #2 of 11 Old 04-14-2010, 11:36 AM
bodybrdng's Avatar
Sounds like a bent prong or loose cable on the harness to me.
bodybrdng is offline
post #3 of 11 Old 04-14-2010, 11:57 AM
ksjeep's Avatar
My drivers side is doing the same thing. I assume the actuator is wearing out.
We the People of the United States, in Order to form a perfect Union, establish Justice, insure domestic Tranquility, provide for the common defense, promote general Welfare, and secure the Blessings of Liberty to ourselves and our Prosperity, do ordain and establish this Constitution for the United States of America.
ksjeep is offline
post #4 of 11 Old 04-15-2010, 03:05 PM
Tank29's Avatar
Well, I guess this is todays question...
Mine started doing the same thing this morning...I'm going to tear the door apart and see what's up this weekend...
2007 JK Unlimited "X"
TF 3" Kit w/4 Arm Flex Kit, TF HD F & R Adj. Track Bars, TF HD Steering Stabilizer, Yukon 5.13 gears, CenterForce II Clutch, Black Rock Soft 8's 16x8, Cooper Discoverer STT 315/75/16, RR XHD Front w/Stinger, SB XRC Rear w/Carrier, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fenders, SB XRC8 Winch
Tank29 is offline
post #5 of 11 Old 04-15-2010, 08:27 PM
tkob1060's Avatar
there is a write up for taking apart the door panel in the write up section fyi
tkob1060 is offline
post #6 of 11 Old 04-17-2010, 01:01 AM
I hardly ever lock mine so I don't have this issue yet, but I'll watch this thread so that I know the fix when it does happen.
post #7 of 11 Old 04-17-2010, 06:25 AM
mb817's Avatar
doors havent seen mine in weeks.
mb817 is offline
post #8 of 11 Old 08-15-2011, 11:07 PM
Jeep2.0's Avatar
Resurrection
Old thread, same question. My Driver's side power door lock isn't working. I can lock & unlock manually fine. The other 3 doors lock & unlock fine. I've unplugged & re-plugged the door in. Power windows work fine.
Did you guys ever find the answer to this & get it working? What did it entail?
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline
post #9 of 11 Old 08-22-2011, 02:29 PM
Some additional information will help trouble-shoot where the problem might be. For example:
If you leave that door open or ajar, do you get the dash warning of a door open?
When you open that door does the interior light go on?
When everything is locked, if you open that interior handle do the other doors unlock?
If you lock that door with the key from outside what happens to the other doors?
There are only 4 electrical connectors to the door latch. Two of them are related to the interior light and ajar indicator. Those two connectors are part of the latch for either the manual doors or electric doors. The other two connectors are part of the electric lock/unlock. So, if part of the function is working (interior lights, door ajar) and the other functions are not, I suspect a bad door latch. If none of the functions are working, then either the latch or door wiring harness. Might be as simple as the connector loose on the latch as well.
Chris
chrisholm is offline
post #10 of 11 Old 08-22-2011, 03:43 PM
Jeep2.0's Avatar
Yes
Yes
I don't think so - need to double check that one.
Edit: I checked tonight - nope, they don't unlock w/ just the door handle.
Nothing
Chris
Thanks for the suggestions. Answers I know are above. When I operate it with the key, the mechanism feels stiff & really hard to turn most of the time. Is the door latch & the door lock actuator the same integrated piece?
Jeep2.0 is offline
post #11 of 11 Old 07-19-2014, 05:03 PM
Jeeprhino
Guest
Posts: n/a
same issue
Jeep 2.0 / Chrisholm : What was the outcome? I am having this EXACT problem. Driver side door, doesn't respond to rke (keyless entry). Others do. Same problem. Please, help.
