LED Help Needed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 03-30-2010, 11:54 PM Thread Starter
Hot Duck's Avatar
LED Help Needed
I am looking for a - 1 LED to be used as both a turn signal and a marker light. In other words it needs to be lit with the headlights to serve as a marker light, but then I want it to blink when using the turn signals. Is there any such LED out there or am I going to have to use a separate LED for each function?
Hot Duck is offline
post #2 of 3 Old 03-31-2010, 10:46 AM
07unlimitedx's Avatar
I ordered some Genright LED lights as front blinkers on my stubby front bumper. I don't have mine as running lights just blinkers. You could use a diode and hook it up with 3 wires, like the front blinkers. Here is the link of the light and a photo that might help.
http://www.genright.com/ProductInfo....ductid=LED1010
07unlimitedx is offline
post #3 of 3 Old 03-31-2010, 11:26 AM
DrHeathenScum's Avatar
The diode/resistor setup will work... depending on the light, you will probably have to fiddle with the value to get a decent difference between dim and bright.
FWIW, most LED lights that small will not have decent light output if you care at all about visibility.
DrHeathenScum is offline
