subs - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 04-19-2015, 02:39 PM Thread Starter
subs
I have a 250 watt jl audio amp and a 10" sub from a previous jeep project Im wanting to wire it in to my 12 jeep rubicon but I want to use both the stock sub and my jl. I mean if 1 sub is good 2 has got to be better. Is this possible?
superdave624 is offline
post #2 of 5 Old 04-19-2015, 06:17 PM
Yes it can be done as along as you split the high level lines to either convert to RCAs or run the high ins if your amp has that capability.
Personally I wouldn't do it. The subs are different sizes, with different frequency responses, etc. I would just run the aftermarket sub, as it will probably sound much better than the factory unit.
I removed my factory sub, then put two JL 8W1s, run in series, in a single chamber down firing enclosure. Sounds 100 times better than the factory set up, and also still thumps with the top down.
98 TJ w/ 5.2/44re/stak 300, coilovers, 40" treps, hp60, 14 bolt, geared, locked, linked, stretched, hilined, . . .
08 JKU Rubi w/ 3.5" RKLA w/Foxes, 37"km2s on racelines, RIPP Supercharger and headers. . .
knobby97 is offline
post #3 of 5 Old 04-19-2015, 09:02 PM Thread Starter
Items needed
Thanks for the advice what all do i need to wire my amp and sub in...I have a 12 Rubicon with mygig ( not sure which one i do know its 28 gig storage ).
post #4 of 5 Old 04-20-2015, 10:24 PM
If you're removing your factory sub, then just take the signal from the factory lines (high output) then use something like an audio control lc2i or other line out converter to get your RCA in for your amp. This is assuming that your amp doesn't have high level inputs, but I'm not a huge fan of them. Then all you would need to do is run your battery + from the battery through the firewall, ground to the frame, then run your rote line from a ignition switched line like your cig lighter.
knobby97 is offline
post #5 of 5 Old 04-23-2015, 05:47 PM
H.I.I.K's Avatar
Can you tell us what amp you are installing?
Maybe they just corrected your ridiculous mistake. Who the fuck orders chrome anything?
H.I.I.K is offline
