extra power outlets - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 03-22-2010, 08:34 PM Thread Starter
leman's Avatar
extra power outlets
im wanting to mount some extra power outlets in the jeep for ipod, gps, cell phone charger, girlfriends vibrator, ect.
can i just tap into the existing power leads for the outlets or should i run a new line from the batt or ign circuit? i would like for it to turn off with the jeep.
2008 steel blue sahara
with some doo-dads
leman is offline
post #2 of 4 Old 03-22-2010, 08:47 PM
CashMoney's Avatar
I would install something like this http://www.summitracing.com/parts/PRF-70203/
or this http://www.summitracing.com/parts/PRF-70207/ Thats what I did in my jeep so I could have full power of the socket and not have to worry about blowing fuses and I also needed power for other things like GPS and my flash light.
CashMoney is offline
post #3 of 4 Old 03-22-2010, 09:18 PM
WeGo4x4's Avatar
Definatly want to run a relay. Both those above will work but you can make a custom one for a bit less $$$. You can pickup a fuse block for about $10 and a relay with socket for about $4. Just make sure you dont go over a 30amp draw and you will be fine. Run the coil power for the relay from your cig lighter and the main power from the battery. I ran a diode between the coil just in case. The diode was about $1 for 2 at radio shack. Then you have a decent supply. You want to make sure you run the proper gauge wire also, but it really is simple.
http://www.amazon.com/Bussmann-BP-15...=pd_sbs_misc_3
http://www.amazon.com/12-VDC-5-PIN-R...xgy_auto_img_b
http://www.amazon.com/VDC-Automotive...d_bxgy_e_img_b
WeGo4x4 is offline
post #4 of 4 Old 03-22-2010, 09:20 PM
WeGo4x4's Avatar
Oh yeah and run a fuse by the battery and the cig lighter. 5amp by the cig lighter and 30amp by the battery. Keep you nice and safe.
WeGo4x4 is offline
