Alls ! hear is static!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 03-22-2010, 02:43 PM Thread Starter
Butler20's Avatar
I have a cobra 29 ltd bt with a 4' firestik II. My swr is at like 0 but i only hear static. I do not know much about cb's. I cant figure out what the problem is. anybody know?
3.5" Rubicon Express lift
Bilstein 5100 Shocks
17x9 Mickey Thompson Classic II
35" Nitto Mud Grapplers
Smittybilt XRC Rear Bumper
Flowmaster 40 Series
48" Hi-Lift Jack
KC Slimlights long range
Rugged Ridge mirror relocation brackets
MasterCraft Grab Handles
Butler20 is offline
post #2 of 6 Old 03-22-2010, 02:49 PM
SONIC's Avatar
First off your swr should be 1 at the absolute best.
Second you probably have something hooked up wrong.
You should have power and ground run to your cb (obviously) Then your Coax routed (away from power wires) the your antenna.
Your antenna should be isolated from the mount by a poly spacer and the mount should be grounded. (there should be a diagram of this on your CB mount box or instructions)
Assuming you have that right, turn your squelch knob until you dont hear any more static....once the static is gone you should be able to pick up and recieve transmissions.
-Doc Holiday
SONIC is offline
post #3 of 6 Old 03-22-2010, 03:13 PM
TheBeatenPath's Avatar
x2 check all your wiring and
the static is called squelch it makes lower power transmission easier to receive.
TheBeatenPath is offline
post #4 of 6 Old 03-22-2010, 03:32 PM
dtcc687's Avatar
yeah if you have static you have a good ground. without a ground you get no static. i have the same exact setup. try turning the squelch down untill the static stops. have you got this radio tuned? the meter on the front of the radio will tell you nothing, its basically useless because the meter itself needs to be tuned, if you take it to a cb shot or truck stuck or have a friend tune it you should be better off. i dont know a whole lot about cbs because this is my first one but i went through all the same stuff about a month ago. i went to a local cb shot and the guy tuned my radio and antenna and tough me a whole bunch of stuff i needed to know about my radio.
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #5 of 6 Old 03-22-2010, 06:04 PM
Send a message via AIM to oneleggedsheep
x3 on the wiring.
Make sure not to wire into other accessories as well. I originally wired my radio onto the switches for my fogs but redid the wiring so it lead straight to the battery... noticeably had less static afterwards.
oneleggedsheep is offline
post #6 of 6 Old 03-22-2010, 06:40 PM Thread Starter
Butler20's Avatar
i have not gotten it tuned. i guess ill have to take it somewhere
48" Hi-Lift Jack
Butler20 is offline
