Throttle response? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 03-19-2010, 02:51 PM Thread Starter
Throttle response?
I am wondering if anyone else has noticed the extremely slow throttle response on their JK. Mine will rev up to around 3000, and return to idle seems to be very slow. Loaded or unloaded! Not good for off road use! And what possible fixes, without getting into aftemarket programmers.
stillovemycj is offline
post #2 of 21 Old 03-19-2010, 05:29 PM
Walldo's Avatar
First off, Welcome. I have heard that most programers or the Sprint booster will fix this problem, but that is just hear say, I don't have any experience with either. Good Luck with your quest.
08 Rubicon, AEV 3.5" lift, Currie Control Arms, 5:13 Gears, Riddler covers, AEV Front and Rear Bumper With Tire Carrier, AEV Pintler Wheels, AEV Hood, 35" BFG MK2's, Warn 9.5 ti Winch
Retired AF 1984-2006
Walldo is offline
post #3 of 21 Old 03-19-2010, 05:50 PM
Grant211's Avatar
superchips - get it....don't be scared
Grant211 is offline
post #4 of 21 Old 03-19-2010, 07:08 PM
John L's Avatar
The slow return to idle is to meet EPA requirements.
/jl
Healthy is merely the slowest possible rate at which one can die.
John L is offline
post #5 of 21 Old 03-20-2010, 10:16 PM
ZOSO-Green's Avatar
Really... please elaborate.
ZOSO-Green is offline
post #6 of 21 Old 03-20-2010, 10:24 PM
X2 I'm curious whether or not I'll have emissions issues if I run the superchips or something similar.
Not to mention it's frikkin annoying
Dancin Dan is offline
post #7 of 21 Old 03-20-2010, 11:03 PM
StubEXrube's Avatar
X2 on this issue- but I have become used to it.
StubEXrube is offline
post #8 of 21 Old 03-20-2010, 11:15 PM
CDavisJK's Avatar
Send a message via AIM to CDavisJK
I think it's annoying too. I've been using the Superchips and the throttle response is much better without it. I disabled it to go to the dealership, and I've left it off for a week because I'm going back on Friday. And I can really notice the difference. I tried to floor it to block off a car from cutting in front of me and I could not do it because he was already in front of me before the throttle kicked in.
CDavisJK is offline
post #9 of 21 Old 03-20-2010, 11:18 PM
RODICON's Avatar
Go with the srint booster!
2014 Rubicon on the build!
RODICON is offline
post #10 of 21 Old 03-20-2010, 11:43 PM
StubEXrube's Avatar
With mine (6 speed manual), I don't have any problem getting it to throttle-up. It's just that it seems like it takes a second or so for the engine to throttle back down to normal. One thing I've noticed with my JK is that it used to idle right under 1,000 rpm's. Lately it is idling lower- maybe around 700- 800 rpm's.
post #11 of 21 Old 03-21-2010, 10:21 AM
John L's Avatar
CFR title 40 section 86.000-8 states:
(4) The air to fuel ratio shall not be richer at any time than the leanest air to fuel mixture required to obtain maximum torque (lean best torque), plus a tolerance of six (6) percent. The Administrator may approve a manufacturer's request for additional enrichment if it can be shown that additional enrichment is needed to protect the engine or emissions control hardware.
If you rev a motor and snap the throttle back to idle it creates a rich condition spike. This spike is in violation of the above text, therefore the mfgs implement the software driven idle speed drop coding in the ECM.
/jl
John L is offline
post #12 of 21 Old 03-26-2010, 11:36 AM Thread Starter
Ok. Looks like I got my answer with the EPA deal. I have planned on a programmer anyways. Down the road! I have become used to it already too. I could also see that the slow reactoin to decrease engine speed would keep the jerking down to a minimum, in a low range situation. So maybe it is a good idea. But a snappy throttle is always nice to hear and feel!!!! Also, I notice that my 2nd gear shift seems to be out of synch. Has tendency to grind a little from 1st to 2nd, but not in any other gear. I am going to get it in to be looked at, but was wondering if anyone elses trans does this?
post #13 of 21 Old 03-26-2010, 11:37 AM Thread Starter
One more questin. What exactly is a "Sprint Booster"?
post #14 of 21 Old 03-26-2010, 12:26 PM
peenkfloeed's Avatar
peenkfloeed is offline
post #15 of 21 Old 03-26-2010, 02:38 PM
spillidge's Avatar
Very interesting post!
I was wondering why my jeep did that, really pisses me off.
spillidge is offline
post #16 of 21 Old 06-27-2014, 11:07 PM
Programmer/Superchip?
I have had my 07 wrangler for 5 years now and I have not gotten used to RPM returning to idle so F'ing slow.. I HATE it.. i have the sprint booster.. it seems to make some difference in response but not really worth the money.. and it makes no differece in RPM coming back down at all.. will anything at all fix this.. I don't care about emissions ... Ill plant a tree every time I drive if its what I have to do to fix it... I'm seriously ready to tear the 4.0 outta my Cherokee and stuff it in there..
Someone mentioned a programmer.. would I be able to fix it that way? Someone also mentioned superchips?,will that fix it 100% or just kinda?? I don't want to spend any money unless it's 100% better.. like an older jeep.. waaaay back when they had a straight six and a throttle cable.
Rolfs is offline
post #17 of 21 Old 06-28-2014, 05:04 AM
kjeeper10's Avatar
Throttle response?
Sprint booster plus SC throttle map. 07/6 speed, 2 door w/ heavier 35's.
Moves along just fine on road.
I absolutely hated acceleration stock driving a TJ for 10 years.
My only gripe is off road. It can get very jerky if I don't stay on the brakes lightly. That and I lost the cord that adjust the SB settings and it's stuck on high lol
I can't say whether the RPM return got better or i just got used to it. I'm thinking the latter and it actually helps maintain rpm when shifting.
Sent from AutoGuide.com App
kjeeper10 is offline
post #18 of 21 Old 06-28-2014, 10:51 AM
Why do you have both? Mine seems responsive enough with just the SC throttle settings. Any more aggressive would make it tough to drive on rough terrain.
Terminator2 is offline
post #19 of 21 Old 06-28-2014, 11:36 AM
kjeeper10's Avatar
Sprintbooster was first. Later came the tuner. Like said ... I lost the cord that goes to the SB. Never removed or tried changing anything.
post #20 of 21 Old 06-28-2014, 12:22 PM
Can you just remove the sprint booster? Or are you missing something to hook the factory pedal wiring back up?
post #21 of 21 Old 06-28-2014, 01:23 PM
kjeeper10's Avatar
I can and will eventually. Both if I decide to regear.
I lost the wire that selects the 3 settings. Been wireless for 2 years.
