Rock Jock 60 ABS BS - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 03-16-2010, 09:31 PM Thread Starter
cjcraig7's Avatar
Rock Jock 60 ABS BS
I don't know if anyone else has had problems with the front rotors cutting the ABS sensor wire, but I have. The sensor wire is molded directional but works in the Rock Jock backward of the design. I sourced a couple of clips and solved the problem, no more ABS or Brake Light. Plus, I think the rear brake drag under the wire cut/light on position?
I tried to search, so if this has been previously covered....
cjcraig7 is offline
post #2 of 4 Old 03-16-2010, 10:14 PM
terrahawk's Avatar
Where did you get the clips?
terrahawk is offline
post #3 of 4 Old 03-17-2010, 08:10 AM
Slippery's Avatar
Yep, just have to clip it or use a tie to keep it away, and then it's no problem.
Slippery is offline
post #4 of 4 Old 03-17-2010, 08:46 AM Thread Starter
cjcraig7's Avatar
Clips
Picked the clips up at the hardware store. Just make sure the clips are pinched just tight enough to keep the wire from slipping, but not damaging the wire. Even after clipping, the wire loop near the sensor is only about a 1/4 inch from the rotating wheel stud cap. I also, took apart the factory wire harness and relocated both plugs where the sensor plugs into, so they don't stretch or just dangle.
cjcraig7 is offline
