Replacing KC's with Rigid's...Do I need to replace wiring? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 03-15-2015, 05:34 PM Thread Starter
Dollar's Avatar
I have a pair of KC Apollo Pro 5" lights on my bumper. I'm replacing them with a pair of Rigid DOT D series lights. The plugs are the same. Can I just swap the lights and keep the KC wiring?
Sorry for the silly question. I hate electrical stuff.
Thanks..
Dollar is offline
post #2 of 8 Old 03-15-2015, 10:19 PM
Random Dude
Thanks..
Assuming you had clean wiring sufficient for the KC Apollos, your DOT Rigids should be totally happy.
If the plugs are the same, go baby go! (UNLESS you have your + and - switched)
ExWrench is offline
post #3 of 8 Old 03-16-2015, 06:46 AM
I used to have 4 KC slim lites on 2 switches, I changed out 2 of them for a 50 inch bar and 2 of them for 2 rigids and 1 12 inch bar.
As long as the wiring you have can still handle it you will be fine.
post #4 of 8 Old 03-16-2015, 04:00 PM Thread Starter
Dollar's Avatar
Well, I wanted to hear a yes or no. The caveat's of "clean wiring" and "the wiring you have" is killing me. LOL.
I used the wiring that came with the KC lights. Ran the power to the battery with the relay and grounded to the chasis. Only thing different is I tapped into the factory harness to be able to use the factory fog switch on the light stalk instead of running their harness inside to a toggle.
So it should be fine. One less thing I have to do. I don't mind rewiring the lights with Rigid's stuff, but an sPod is in my future and I don't want to do things three times. I figure I'll keep em with the KC wiring until I upgrade.
The KC's were 55W and the Rigids are 33W. Never really wanted Rigids, but these are their DOT/SAE compliant fog lights, so I'll see how they work with everyday driving.
Thanks again.
Dollar is offline
post #5 of 8 Old 03-16-2015, 04:39 PM
Random Dude
Thumbs up YES
YES
^ BETTER?
You say the plugs are compatible, so plug 'em in, already!
Your existing wiring should be more than sufficient for the LED's amp draw.
If it's not fooked up in any way, your harness is good to go.
If your "+" and "-" are correctly oriented, the lights will be all shiny. If not, swap the wires at the plug.
"Sorry" for all the technical bullshit electrical jargon.
We were trying to explain why a simple "yes" or "no" wouldn't do.
Please report back on the performance of the Rigid DOT fog lights.
When I crack another KC Slimlite fog, those are on the short list of replacement candidates.
ExWrench is offline
post #6 of 8 Old 03-16-2015, 04:42 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Pffft, people wantin' direct answers!
No, you can't reuse the wiring, because it's red and black. That is very confusing and should be swapped out for wiring that is instead black and red.
JKCTAZ is offline
post #7 of 8 Old 03-16-2015, 06:10 PM
Treader's Avatar
Well you all gave a direct answer in the Firewall thread. What was it, push in and out through the hole.
2010 2 door manual sport
Treader is offline
post #8 of 8 Old 03-16-2015, 11:20 PM Thread Starter
Dollar's Avatar
Red and black. Black and red. Up and down. Down and up. I knew I should've taken it to the dealer for the install.
When I finish installing my winch, I'll put in the lights and will report back. I'll be driving to EJS next week, so I'll have plenty of night driving to test them out.
Dollar is offline
