cb question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 03-15-2010, 03:26 PM Thread Starter
dtcc687's Avatar
cb question
so i have my cb on the dash and i wanted to hide my wires. so i made a peice of sheet metal at work and ran it down the windshield so you couldn't see the wires. i held it in place by screwing it with the 4 metal screws in the side of the cb(the ones used to hold the cover on the cb). i went to the store about 5 mins after installing my new shield to hide my wires and i smell something like burning electronics. i feel my radio and its burning hot. so i shut if off and got right to work on taking this new shield off. and soon as i took it off and put everything back to normal the radio was fine. i guess i got to it just in time before the whole radio burned up. but i want to know what went wrong. was this piece of metal somehow grounding something or causing a connection somewhere it shouldn't have. am i at risk of having a damaged radio now? i dont think i broke anything because it seems to work fine still and its no longer getting hot now that i took the metal piece off. i also wanted to know if i can cut a hole in the top plate of the radio to add ventilation so something like this would not happen again. not that im going to be messing with the radio anymore i just dont want it to over heat for any reason.
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #2 of 4 Old 03-15-2010, 03:40 PM Thread Starter
dtcc687's Avatar
heres what i have in mind for a vent. i have these grills left over form when i used to build computers. i belive its about 3 inches and i wanted to take the top plate off use a hole saw and cut a 3 inch hole in the top and put this grill over it.
Name:  120mm fan grill (Custom).jpg
think that would work or should i just leave it alone?
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #3 of 4 Old 03-18-2010, 01:38 PM
Joe C's Avatar
sounds like you shorted something in cb or in the wiring. if that's the case, a cooling vent will not keep you from burning up your cb
2017 4 Door Rubicon
Midland 75-822 with 3' Firestik
Joe C is offline
post #4 of 4 Old 03-18-2010, 01:45 PM
WeGo4x4's Avatar
I agree. Something is really wrong. Your CB shouldn't heat up like that. Has to be a short.
WeGo4x4 is offline
