Brake lights gone erratic... help!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 03-08-2015, 09:14 AM Thread Starter
As of the last week my jeeps wiring has gone erratic. I pulled the power terminal off of the battery last week and I thought it fixed it but I was wrong.
When I apply my brakes my front orange signal/marker lights light up. All my wiring is stock. It does it only when my headlamps are in the off position. Oh and my drivers side rear brake light is stuck in the bright position. I changed the bulb, no fix.
Any thing like this happen to anyone yet? Probable cause? Fix?
-GlennH
GlennH is offline
post #2 of 4 Old 03-10-2015, 07:38 PM Thread Starter
bump anyone?
GlennH is offline
post #3 of 4 Old 03-10-2015, 07:49 PM
Jonboy's Avatar
Electrical problems suck, for sure. Have you installed anything that has tapped into any factory wiring?
Just for fun, I'd probably check that my battery was putting out 12V and isn't going out. Assuming that''s not the problem, it could be the TIPM going out.
Jonboy is offline
post #4 of 4 Old 03-10-2015, 08:10 PM
BigTB's Avatar
I've seen really weird issues with lights like that when a ground is bad somewhere. I had a car that had a similar type of issue and the root cause was a corroded ground in one of the bulb sockets. When you get a bad ground power will often find it's way to a ground through other bulbs, through switches when they are in certain positions, etc.
I know that doesn't help much.
Good luck.
Edit: I would pay special attention to the ground of the light that stays in the bright position. It could be that if the ground is missing, instead of power going across the "dim" filament and to ground, it goes across both filaments, and grounds through a switch somewhere. Just a thought. That is basically what was happening on the car I worked on.
Also, when you apply the brakes, does the "stuck bright" light go off completely? That would support the bad ground theory.
BigTB is offline
