New OEM satellite radio - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 03-13-2010, 05:43 AM Thread Starter
popojk's Avatar
Has anyone replaced their OEM radio, without satellite radio, with an OEM radio with satellite? If so, what else did you need to buy, besides the satellite radio service? If I buy one off E-bay does it have a special code to make it work??
popojk is offline
post #2 of 14 Old 03-13-2010, 05:48 AM
I'm just guessing here, but I think you would also need the satellite radio antenna. I know I have a special antenna just for Sirius radio mounted above the passenger side B pillar.
08 Unlimited Steel Blue
All Sorts of Crap on it
In the space of about 30 seconds, this man was in a car accident, an explosion, lit aflame and then kicked in the balls with more force than a human foot can technically take.
Future terrorists take note: this is your retirement package.
lockednloaded is offline
post #3 of 14 Old 03-13-2010, 06:09 AM
Mr.RonGilbert's Avatar
I have a portable that I use in the JK, at work, at home etc.... so I am not familiar with the integrated head unit. I am almost certain that the same thing applies though. You will need an antenna and the radio's ID/ESN number once you have the radio installed (simple) and the antenna hooked up (pointed skyward, mine is on the to of the soundbar) you tune to channel 184 and will most likely be getting the "subscribe" channel, just talk - like a Sirius/XM commercial over and over if I remember correctly. You can call them at 1-888-539-SIRIUS (7474) or online here there is a tab that says "activate now"
Should be very simple.
Mr.RonGilbert is offline
post #4 of 14 Old 03-13-2010, 12:39 PM
eggwhite93's Avatar
You will need one of these.
http://www.justforjeeps.com/sisarakit.html
Marc
2007 2 door Rubicon ROCK KRAWLER - POYL PERFORMANCE - RIVER RAIDER - POISON SPYDER - BILSTIEN - PITBULL - ACE - SMITTYBILT - BLACK ROCK - SUPERCHIPS - SPIDERWEB SHADES
eggwhite93 is offline
post #5 of 14 Old 03-13-2010, 04:54 PM
chili_p's Avatar
I just did this in my 09. I just went to Radio Shack and bought a Sirius antenna it was like $20 or so. Pulled my stock non sat radio put the sat radio in with the antenna hooked up (I put the antenna on the sound bar) and it worked. You will need the ID number off the top of the sat equiped radio. Just call Sirius and they will hook ya up.
2009 JK X 2 Door, Auto, Soft Top, Deep Water Blue Pearl
Terra Flex 2.5" BB,Bed-lined Rubi Rims/Tires, sPOD, FLW Rock Sliders.
Ordered Finishline West Chubby 2.0 now waiting on UPS or FedEx.
My other hobby
chili_p is offline
post #6 of 14 Old 03-14-2010, 06:17 AM Thread Starter
popojk's Avatar
Thank you; as long as I know it will work without any problems. I didn't want to put the portable sat radio, because it's just another loose item for someone to take.
popojk is offline
post #7 of 14 Old 03-14-2010, 06:25 AM
ksjeep's Avatar
NO KIT NEEDED! Just go to an electronics store and buy the antenna with the orange connector. Install, call 800 #.... you got music!
ksjeep is offline
post #8 of 14 Old 03-20-2011, 02:03 PM
cruzcode's Avatar
I'm tearing into mine right now. How did you guys install the antenna to the cage? Tape? Velcro? Roll-bar Bracket?
RC
A lot of chit coming...
W9DRC
cruzcode is offline
post #9 of 14 Old 03-20-2011, 02:14 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
RC
Mine had a magnet on it, it took like 5 minutes to install
Dr.Dirty is offline
post #10 of 14 Old 03-20-2011, 02:20 PM
cruzcode's Avatar
Thanks, Dirty...
I bought the antenna off of eBay, and it came with a ton of cable. Then I bought the cable to connect the antenna to the head unit from the stealership. I think I may have a compatible antenna, that wasn't designed for the JK though. Everywhere I see pictures, the antenna has like 6-7 inches of cable, where mine is really long.
F*** it. I'll tear it apart and check it out.
RC
W9DRC
cruzcode is offline
post #11 of 14 Old 03-20-2011, 02:22 PM
Dr.Dirty's Avatar
I ran mine along the cage under the padding and ended up with teh antenna right on top of the sound bar between the driver/pass head.
Dr.Dirty is offline
post #12 of 14 Old 03-21-2011, 02:35 AM
cruzcode's Avatar
Yeah, I ran mine in the factory location on top of the sound bar plate, running the wire down the inside the B Pillar, along the floor trim, and into the dash. It looks great.
I can't tell if it works, because the factory satellite radio I bought here online doesn't work, and came from an individual seller. :angry:
RC
W9DRC
cruzcode is offline
post #13 of 14 Old 03-22-2011, 08:23 PM Thread Starter
popojk's Avatar
The OEM radio I bought online didn't work either. When I installed factory fog lights I had to go to the dealer and have them update the computer, so they would work with a factory switch. I wonder if I need to go to the dealer to have the radio turned on??
popojk is offline
post #14 of 14 Old 03-27-2011, 07:12 AM Thread Starter
popojk's Avatar
Does anyone have an answer to buying a used OEM radio, and having to take it to the dealer to have it turned on?
popojk is offline
