Radio cuts out on bumps, ESP/BAS/ABS on harder bumps - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 03-03-2015, 06:10 AM Thread Starter
kbiv's Avatar
2010 Unlimited Sport, I replaced the factory single CD/MP3 deck with a Clarion CZ702 and used the CANBUS adapter from Crutchfield (Metra XSVI-6522-NAV). I soldered all of the connections for the adapter and the radio harness, and covered them in heat shrink. This has worked great for a few months.
Cue the snow/ice storms of the last several weeks. After playing in the snow, I hit a bump and the radio cut off, ABS, ESP/BAS, and BRAKE lights lit up, and I heard a warning "ding". Lights were only on for a split second, then off, and radio came back on. Since then, depending on the size bump I hit, it varies. Small bumps just affect the radio, larger bumps affect the dash lights listed above and the radio.
I'm leaning toward a wheel speed sensor problem for the lights, but could this also affect the radio? Any thoughts?
kbiv is offline
post #2 of 4 Old 03-03-2015, 08:34 AM
ledzep_06's Avatar
most likely, id be looking for a poor/loose connection.
ledzep_06 is offline
post #3 of 4 Old 03-03-2015, 05:02 PM
Pull the abs sensor cables off each wheel and clean out and reconnect.
You can get to them easily enough. Fixed an issue I had that sounds similar
aus-jeep is offline
post #4 of 4 Old 03-03-2015, 06:23 PM
It never ends...
LeftHandRubi's Avatar
I had something like that. It got progressively worse. Turned out it was the TIPM gone bad.
I agree with others: check connections.
If it progresses to worse, then maybe think tipm.
T-REX
Meet Rex Thread:
Adventures of Rex Thread:
LeftHandRubi is offline
