Cheap "on board air" - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 02-21-2015, 08:36 AM Thread Starter
Hey guys i posted my welcome post and im always modding my jeep so i figured id share my last mod.
I did a on the cheap on board air to fill my tires up after a day of wheeling or incase i forget to air up, or find a damsel in distress
so i went to my local canadian tire and picked this up
http://www.canadiantire.ca/en/pdp/mo...l#.VOihRi5OVqE
this was the only thing my store had in stock. i specifically was looking for something that you can set the air pressure and walk away. i didnt read any reviews before i purchased so here goes nothing.
first thing i did was tear apart the compressor to see what was all in it.
looked fairly simple to be honest so i tore apart the jeep
i mounted the compressor into the tailgate of the jeep
and mounted the screen in the back panel
this is what i assume to be the pressure sensor, i had to extend these wires to the controller, also had to extend the power wire to the compressor
put a bulkhead brass fitting through the gate and put the plastic cover back on.
i purchased the daystar lower dash panel for inside the cab and ordered some switches (not here yet so not connected) to power this compressor
Heres the final setup being used for the first time to do some time trails and make sure it works. im using a 20 foot coil hose
so if anyones curious on how it works. my current tire set up is 305/70/16 nitto mud grapplers. i aired the tire down to 15 psi. (which the digital screen agreed with after i plugged it it) set the module to 30 psi and hit start. 7 minutes later the compressor turned off and tire was full!!
as far as i can tell this system is completely upgradable, so i plan on installing either a second compressor or a larger on in place of this one.
feel free to share thoughts or ask questions. ill answer best i can
Colonel6632 is offline
post #2 of 9 Old 02-21-2015, 08:44 AM
Good job! How hot does the compressor get in the tailgate?
Mtljeep is offline
post #3 of 9 Old 02-21-2015, 08:54 AM Thread Starter
well its mounted right in front of the plastic vent so it gets lots of ventilation. but during my tests, i couldnt feel any heat.
post #4 of 9 Old 02-21-2015, 12:57 PM
2Door's Avatar
Each tire took 7 mins?? Damn, a half hour. Super trick setup though! Very clean.
2011 Sahara Tan 2dr Rubicon
2Door is offline
post #5 of 9 Old 02-21-2015, 02:33 PM Thread Starter
ya sadly it takes a while. but its nice that you can walk away and leave it. and its expandable for a bigger compressor later on
post #6 of 9 Old 02-21-2015, 07:10 PM
barrydd's Avatar
Nice. I like the location.
USMC
barrydd is offline
post #7 of 9 Old 02-21-2015, 07:32 PM
Guruman's Avatar
Makes me wonder if I can ram my Extremeaire compressor in that space. Great idea.
I also wonder if a small compressor in this space, combined with one behind each taillight and plumbed and wired together would make enough combined air to be useful. Three small compressors would still be pretty cheap, plus you'd gain some redundancy, if one or two compressors bit the dust, you could still air up, albeit slower, with the remaining unit(s).
_
Guruman is offline
post #8 of 9 Old 02-21-2015, 07:50 PM
It takes a while to air up with a small compressor.
I am usually too lazy and either drive home or to the nearest gas station with 12lbs of air in my tires.
Probably increases tire wear but I won't spend half an hour waiting for the tires to fill up.
Mtljeep is offline
post #9 of 9 Old 02-22-2015, 08:18 AM Thread Starter
well the plan is to later get a vair onboard air compressor, a pneumatic solenoid, and an air tank. the compressor will build the tank up to 130psi with a quick coupler for air tools, then have this tailgate coupler still for airing up tires with the digital controller.
