CB install pics - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 03-07-2010, 02:33 PM Thread Starter
jeeperjkj's Avatar
CB install pics
Is there a write up anywhere on this? Yeah, I'm sure it's been discussed, but I'm a visual kind of guy and I like pics.
Can some of you take pics of your install spots, wiring, antenna mounts, etc.?
Thanks in advance.
jeeperjkj is offline
post #2 of 14 Old 03-07-2010, 02:39 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
Dr.Dirty is offline
post #3 of 14 Old 03-07-2010, 04:06 PM Thread Starter
jeeperjkj's Avatar
Thanks. There are a few good pics in that one.
What about the antenna?
post #4 of 14 Old 03-07-2010, 08:41 PM
TheBeatenPath's Avatar
click this link if you wanna make a antenna bracket its really easy
https://www.jkowners.com/forum/showthread.php?t=21331
TheBeatenPath is offline
post #5 of 14 Old 03-19-2010, 08:29 AM Thread Starter
jeeperjkj's Avatar
Ok, guys, since #1, I'm lazy and procastinate alot; #2, I've been busy with other stuff; #3, I haven't figured out just how yet... I haven't installed my CB yet.
The instructions say to put the red wire direct to the battery, the orange wire to an accessory outlet (i.e. cigarette lighter), and the black to (obviously) ground. My question is, where is a good wire for the orange? Do I need to buy something like http://www.quadratec.com/products/96080_98.htm this from Quadratec? I don't think I need the parts, but it might be worth it just to know which wire they're talking about.
I'll figure out a mounting spot. I just need someone here to help me out with the wiring part. Can someone tell me how you've wired yours?
If there's anyone in this area that cares to help me, then let me know. I could probably make a little road trip next week sometime.
post #6 of 14 Old 03-19-2010, 09:36 AM
I was thinking about running my CB to a switch, anyone done that before?
2008 Patriot Limited 4x4
2010 Jeep JK Sport 2dr/6spd/3.73's
Go visit
...and tell your friends!
SmurfJK is offline
post #7 of 14 Old 03-19-2010, 09:48 AM Thread Starter
jeeperjkj's Avatar
That'd be sorta redundant since there's already an on/off switch.
post #8 of 14 Old 03-19-2010, 10:13 AM
Just thinking you could mount it in/under the glove box, leave it on, and just flip the switch when you need to use it..
Go visit
SmurfJK is offline
post #9 of 14 Old 03-19-2010, 01:52 PM Thread Starter
jeeperjkj's Avatar
I thought of that, but I'm not sure how well it could be heard in the glove box. I'm still trying to figure out where I want to mount it, too.
post #10 of 14 Old 03-19-2010, 01:59 PM
post #11 of 14 Old 03-19-2010, 02:42 PM
sniper41's Avatar
I'm usually around and am off Monday, and will be here Sunday if you wnat to do the road trip to the big city!! If Haddonfield can be called that. That way you can look at how mine was wired and I'd be glad to help you with installing and what not! Just let me know or PM me Jeeper!
Jersey
Crew
sniper41 is offline
post #12 of 14 Old 03-19-2010, 03:07 PM
JIMBOX's Avatar
Mine is over the rearview mirror and I have it wired thru the overhead sw panel, to just flick on/off
Antenna's on the 3rd brakelight stalk
JIMBO
Man, you gotta have style
"YELLOW JEEP No. 683"
JIMBOX is offline
post #13 of 14 Old 03-19-2010, 03:19 PM Thread Starter
jeeperjkj's Avatar
Two questions on that setup. I think I'll have enough room with it mounted there.
#1 - where did you run the ground wire to?
#2 - where did you pass the hot wire through the firewall?
post #14 of 14 Old 03-19-2010, 03:39 PM
i have the carpet out as you can see. see where that red wire is leading to well its like a empty spot that leads to the other side.i attached the hot and the ground wire and ran it thru there. their is a bolt right on the other side in the passenger footwell. thats where its grounded at.basically the bolt to the left of the yellow! sticker is wehre its grounded but the passenger side as i had enough wire to do so.
i also put in a quick disconnect on both wires so i can easily remove it. the white box is the fuse box so instead of opening that to disconnect and risk losing the fuse i just did it to both wires
and i ran my hot wire thruthe drain plug in the passenger side footwell. foolow the crossmember and if you look up there is light coming in between teh inner fender and some other liner. attach the hot wire back on to a hanger that is straightened out and have somebody above to grab the wire and attache it to the battery
