2008 JK Unlimited Fuse Question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-16-2015, 10:12 AM Thread Starter
I have used the search bar both here and google and come up with nothing. I have a 2008 Wrangler that has a draw on the battery. I seem to have it isolated to fuse J15 (Rear Blower). I pulled the fuse 5 days ago and let the Jeep sit, it has maintained 12 volts. Can someone help me out explaining what J15 does. I would love to track down a wiring diagram and see if I cant trace this problem out. Any help or advice would be greatly appreciated.
TMACKY is offline
post #2 of 7 Old 02-16-2015, 10:28 AM Thread Starter
More Info : Base model, Soft top, manual transmission
TMACKY is offline
post #3 of 7 Old 02-16-2015, 10:49 AM
ronjenx's Avatar
Does your 2008 JK actually have a rear blower?
ronjenx is offline
post #4 of 7 Old 02-16-2015, 10:53 AM Thread Starter
No it does not, thats why I am confused that there is a fuse still in the fuse block
TMACKY is offline
post #5 of 7 Old 02-16-2015, 11:13 AM
ronjenx's Avatar
There are several fuses in the TIPM that don't have a function due to the option not being installed.
That fuse feeds a pin that connects to a harness under the TIPM. With no rear blower installed, there is no wire in the harness to connect to the pin.
The fuse is fed by relay K9, which has no control contact, so the coil should never be energized.
So we come down to your battery voltage readings.
You said after 5 days with the fuse out, it maintained 12 volts. In order to evaluate that reading, we need to know a more exact reading, such as 12.6, or 12.3, etc.
What is the battery's voltage reading right after shutdown?
With the fuse in place, what is the voltage reading after a day of sitting?
With the fuse out, what is the voltage reading after a day of sitting.
Do you have a meter you can use to monitor real-time draw on the battery?
ronjenx is offline
post #6 of 7 Old 02-16-2015, 12:03 PM Thread Starter
Ok my sincere apologies for leaving out this crucial piece of info but I do have K9 out of the Jeep as well as J15.
After 2 days sitting it was at 12.3.The reading as of this morning was 12.3. I just started it let it run for 5 minutes, pulled it inside and shut it off and its currently at 12.4.
No start as been an ongoing problem for some time and I had made a spreadsheet with all the fuses listed and systematically pulled fuses until I could narrow down what was causing the draw. There is no constant draw to be able to track down. It would sit for 2-3 days and start no problem with no draw then the next day an absolutely bone dead battery.
I have access to a friends AllData account and all of the wiring diagrams but I cannot find anything associated with a rear blower. As of last week I had it narrowed down to the IOD main or the rear blower. I pushed the IOD main back in on thursday of last week after a week of sitting. Battery measured at 12.3 volts when I pushed IOD back in.
The simple solution is to just leave the fuse and relay out and I understand that but my jeep has a history of multiple jeep service centers looking into this issue and its never been resolved. I am hoping to see this though and find the exact cause.
TMACKY is offline
post #7 of 7 Old 02-16-2015, 12:51 PM
ronjenx's Avatar
I'm not sure if you are saying it's better with J15 pulled, or not better.
Check the voltage with the engine running. It should be around 14.3v.
Check the voltage with the engine off, after it has been run long enough to get a good charge. It should be well above 12.6v.
Disconnect the battery negative cable, and let it sit for a day, then read the voltage. It should stay above 12.6.
After this, you should have a better direction to proceed.
ronjenx is offline
