Bulldog LEDs and SPOD - Wiring noob - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 02-07-2015, 05:16 PM Thread Starter
JeepGeek's Avatar
I have a question that I hope you guys can help with. I just finished installing an SPOD into my 08 JK and received the lights I ordered from Bulldog Lighting.
The Bulldog LEDs come with a nice wiring harness and a switch. As I want to run these from the SPOD, I don't think I need all the wiring harness.
The wiring harness comes with a 40a relay, the on/off switch and a fuse holder. Can I attach the harness to the light, and run power and ground to the Spod and cutout the relay and switch section of the harness? I realize I would need to splice/solder the wires together after cutting out the relay and the switch wiring. But I just want to make sure this is the correct way to proceed.
JeepGeek is offline
post #2 of 2 Old 02-07-2015, 05:29 PM
you can cut the wires off at the length you need. connect the wires to the Spod and you are done. simple
2012 Black JKU , 2.5 RockKrawler lift, 285/75-17 nitto terra's, Custom AtoZ sliders, AtoZ bumper with Quadratec I9500 winch..
jkwirfel is offline
