OK, this is wierd - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 01-27-2015, 06:52 PM Thread Starter
OK, this is wierd
So I put my Rubicon in 4-W drive & locked both diff's the other night. To make a long story short my front diff won't unlock. So I went thru all the usual routine to no avail. I decided to unplug the harness at the diff. to see if would unlock, tried to start it & nothing. Dead. Jumped it off still locked? This is an '07 with 49k miles, I have put it in 4-w/locked about 4 times sine I've had it. Ideas?
Bladerunner is offline
post #2 of 5 Old 01-27-2015, 09:07 PM
evdog's Avatar
I had this issue a little while ago. I put front on jack stands. Drained diff fluid. Pulled cover off. Used a flat head screw driver put it between the plate and pryed a little the plate popped back to unlocked. Cleaned out the whole diff made sure it all worked properly. Then put cover back on and fill
VE7 ESH
evdog is offline
post #3 of 5 Old 01-28-2015, 08:40 AM Thread Starter
I was thinking about doing that, Stumped about it going dead though. May just be coincidence. What'the best fluid to replace with?
post #4 of 5 Old 01-28-2015, 01:57 PM
drew's Avatar
Rockin'
Had the same problem a couple times on my 2008. I rocked it back and forth a few times, kept hitting the switch and it finally unlocked.
drew is offline
post #5 of 5 Old 01-30-2015, 05:51 PM Thread Starter
Jacked it up, pulled the plug, popped the ring back. I think I'm going to change the gear fluid, drive it awhile then try locking and unlocking it again.
