power inverter question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 02-27-2010, 09:50 AM Thread Starter
jeepersheart's Avatar
for those of you with power inverters installed, what are they rated at? I am having some trouble deciding just how many watts would be overkill for a jeep.
2008 Detonator 2Dr. 6 Sp.
Jersey
Crew
jeepersheart is offline
post #2 of 14 Old 02-27-2010, 09:59 AM
JIMBOX's Avatar
I've got several, but none installed on the jeep, just one 750 watt on my off-road trailer, why would you want one INSTALLED on your jeep ???
JIMBO
Man, you gotta have style
"YELLOW JEEP No. 683"
JIMBOX is offline
post #3 of 14 Old 02-27-2010, 10:06 AM Thread Starter
I have seen a few people mount them in the jeep, like under the seat or somewhere hidden, and run the outlets to the center console or wherever else they wanted. I wouldnt mind doing this to have power for lights or tools on the trails. Or maybe even blenders and the such when "camping". I imagine some of the same reason you wanted one for your offroad trailer... I just dont have a trailer.
Jersey
Crew
post #4 of 14 Old 02-27-2010, 10:14 AM
JIMBOX's Avatar
Heh Heh, I can digit, I think you just need to decide how big and where to put it, for wiring size and HEAT, usually 750/1000 watts inverters are from &75 to &150 bucks and will handle small current draws
Good luck
JIMBO
JIMBOX is offline
post #5 of 14 Old 02-27-2010, 10:43 AM
I have a 1000 in my jeep to power my laptop and an X-Box simultaneously at the same it also charges my kids DS. Ive had a 750 in one of my vehicles and it wouldnt run a laptop x-box combo so i stepped up. you can usually pick up a 1K at a truckstop pretty cheap
finishlinewest is offline
post #6 of 14 Old 02-27-2010, 11:28 AM
Loki646's Avatar
Stuck a tiny 150watt under my glovebox and then ran wires to the switch & outlets that are installed in the center console. These are mainly for the occasional phone charger in case you don't have a car adapter but more often than not its for my Macbook Pro that has my GPS info. I'm planning on a 750-1000 watt for the cargo area as well.
Loki646 is offline
post #7 of 14 Old 02-27-2010, 12:08 PM
Nice and clean!
post #8 of 14 Old 02-27-2010, 02:04 PM
Moose512's Avatar
Here is the thread on my install of a 1500W Cobra inverter...
https://www.jkowners.com/forum/showthread.php?t=22405
Moose512 is offline
post #9 of 14 Old 02-28-2010, 12:05 AM
It really depends on what you're going to be powering with the inverter.
My laptop powers off one of those small 75watt inverters fine. I ran a PS2 and a laptop off of a 550Watt one plugged into a power port/cigarette lighter with no problems.
One thing to keep in mind, because the higher wattage you go, it will depend on where you plan to draw the power from. For example, the power ports will handle up to 20 Amps of current....if you consider the battery provides 14 volts when the engine is running, then that equates to 280 Watts of total available power. With the engine off, the battery voltage drops down to 12 volts....so that's 240 Watts of available power. You can't get more Watts out of the inverter, than what you put in to it. So if you get anything above 280 Watts, you will need to directly connect to the battery to be able to use all that available power.
Rednroll is offline
post #10 of 14 Old 02-28-2010, 06:57 AM
JIMBOX's Avatar
Just be careful, most pwr outlets (cig ltrs), are fused at 10 amps and all male DC vehicle outlet plugs, have a 10 amp fuse internal !!
JIMBO
JIMBOX is offline
post #11 of 14 Old 02-28-2010, 09:08 AM
We have one a 1500w installed on the company truck which goes out and does our underground. Its just a Dodge 3/4 ton. Makes nice when using the porto. bandsaw and such. No ext. cord after ext. cord after......you get the idea.
I have also been planning one of these installs. I would want to be able to power my electric impact, and other tools/toys when the time is needed.
localsprink669 is offline
post #12 of 14 Old 03-02-2010, 09:01 AM
Just a note on the cheaper inverters. They are mostly modified sine wave instead of pure sine way and some electronics and induction motors really hate modified sine wave. I picked up a 300/600 pure sine wave I will be installing my jeep when I am unburied with snow.
Mallow is offline
post #13 of 14 Old 03-02-2010, 05:33 PM
scottrock's Avatar
I've got a 400W (800W peak) marine grade wired up straight to battery (fused of course).
I've ran fans, lights, laptops, cell phones, drill... but it wont power anything with a heating element. It's been there for over a year. Been hosed down, etc. It keeps right on tickin.
scottrock is offline
post #14 of 14 Old 03-06-2010, 12:48 AM
WeGo4x4's Avatar
Got to figure what you are going to use it for. I have a 400w under the seat plugged into my power distribution box. It barely ran a small 1 gallon AC air compressor, but it works great for the laptop and such. I'm using the 400w mainly because im using a 30amp circuit to power it and didn't want to run a seperate power feed.
WeGo4x4 is offline
