back up lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 02-21-2010, 07:08 PM Thread Starter
leman's Avatar
back up lights
can i splice a 55w light straight into the reverse light harness? or should i splice in a relay then the relay trigger the light?
i know the safest bet is just to go ahead and run the relay. but would it be ok to do it without one?
TIA- Lee
2008 steel blue sahara
with some doo-dads
leman is offline
post #2 of 22 Old 02-22-2010, 10:40 AM
John L's Avatar
I wouldn't chance it, the relay is the best way to go. There's room behind the left taillight to mount it.
/jl
Healthy is merely the slowest possible rate at which one can die.
John L is offline
post #3 of 22 Old 02-22-2010, 12:38 PM Thread Starter
leman's Avatar
alright man appreciate it
with some doo-dads
leman is offline
post #4 of 22 Old 02-22-2010, 12:55 PM
usmcdoc14's Avatar
the "bestest" way is to run one relay to ground switch another relay so you can run a switch to the dash that also turns on your aux reverse lights
(and some people are going "whut?"
A relay as you know is an electromagnetic switch allowing you to switch larger amounts of power with a very small amount. This way you can run a light amp wire to the switch and not have to worry about frying a switch.
But a relay does not care what it is switching it can switch power OR ground, it just completes that circuit when its electromagnet is powered.
Now this comes into play when wanting multiple switches for 1 item, like reverse lights. A switch to go on in reverse (trans) and a switch on the dash to turn them on anytime. But if you run 2 POS switches to something it will fry something in the process when both are "on" at the same time. But you can multiple ground with no issues. This is how the interior lights in older cars work, the door switch "grounds" and the light comes on.
Lights get constant power, no switch on POS just fuse.
So you run the factory reverse lights to switch one relay, to complete the ground for the lights.
You wire another relay to be switched via switch, to complete the ground for the lights.
So now you can be in reverse (one switch) and have the dash switch on (2 switch) and nothing gets fried as all you have is a better ground.
usmcdoc14 is offline
post #5 of 22 Old 02-22-2010, 01:33 PM
dtcc687's Avatar
use a relay, just splice your reverse light wire to power the relay so when you back up lights come on so will your new lights
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #6 of 22 Old 02-22-2010, 01:48 PM
SFCCotton's Avatar
Mine are hooked up to my SPOD and into my reverse light wiring. I can turn them on with a switch and they come on when I put it into reverse.
SFCCotton is offline
post #7 of 22 Old 02-22-2010, 02:44 PM
RubiZealot's Avatar
This is too coincidental. I was just finishing a diagram to better ask my question when I see this thread. So at the risk of being redundant, I want to wire up my LoD reverse lights so that my S-pod switch will enable the LoD lights. I can choose to have the super brights on or not and still remain DOT compliant.
Please see the rudimentary picture for my design. The LoD lights can't function without the factory lights being on.
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline
post #8 of 22 Old 02-22-2010, 04:37 PM
Zack Massey's Avatar
I wired my lod reverse light straight in to the reverse lights. I have been running them like that for 7 or so months and no problem. I figured mine don't stay in reverse long so I tried it. One thing I did figure out is that the jeep wires got crossed from the factory. I had to check each one to figure out how to do it. Another words both sides of the wiring didn't match up
Zack Massey is offline
post #9 of 22 Old 02-22-2010, 06:32 PM Thread Starter
leman's Avatar
thanks guys, looks like ill be going with the relay for the ground like doc suggested.
with some doo-dads
leman is offline
post #10 of 22 Old 02-22-2010, 06:43 PM
Grant211's Avatar
Question
what about something like this?
Grant211 is offline
post #11 of 22 Old 02-22-2010, 07:09 PM
RubiZealot's Avatar
I'm just so disappointed that your rims aren't also yellow. You didn't try hard enough. :-)
post #12 of 22 Old 02-22-2010, 07:23 PM
H3ATH3N's Avatar
So does this drawing represent what you are explaining doc? Is doesn't appear to considering you refer to multiple relays.
Life moves pretty fast. You don't stop and look around once in a while, you could miss it.
H3ATH3N is offline
post #13 of 22 Old 02-22-2010, 07:32 PM
Tony23's Avatar
Does anyone have any pics of the back up lights hooked up to the reverse lights with the relay?
Tony23 is offline
post #14 of 22 Old 02-22-2010, 08:43 PM
usmcdoc14's Avatar
here, shitty drawing
either switch grounds the lights and turns them on and both can be turned on with no risk
mine are sealed in a ziplock back behind my drivers side tail light
post #15 of 22 Old 02-22-2010, 09:33 PM
RubiZealot's Avatar
Doc's solution appears to turn on the lights either if you're in reverse or also when you're not. My solution requires you to be in reverse which is what I think DOT wants. If that's not a hard requirement, this could be a lot simpler.
post #16 of 22 Old 02-22-2010, 10:12 PM
Stickerboy111's Avatar
Mine have been wired straight to the reverse lights for about a year now and no issues. Done this many times on previous cars etc... Never any issues!
2008 Unlimited Rubicon JK
Detonator Yellow
2" Zone Offroad Spacer lift
SuperWinch LP8500
128CH Kenwood VHF
Cobra 40ch CB
Custom Axe&Shovel holder
Custom Jerry Can Holder
48" Highlift
Air Compressor
Rampage Grab Handles
Congo Rack
"Good roads bring BAD people, Bad roads bring GOOD people"
Was I banned? Hell Ya
Eddie is an Ass Clown
Stickerboy111 is offline
post #17 of 22 Old 02-23-2010, 09:15 AM
H3ATH3N's Avatar
Perfect. Thanks DOC!
H3ATH3N is offline
post #18 of 22 Old 02-23-2010, 09:32 AM
Hey Grant where did you find that light? thanks
tfire is offline
post #19 of 22 Old 02-23-2010, 09:38 AM
ksjeep's Avatar
I like Doc's... if some prick has his bright lights on....
ksjeep is offline
post #20 of 22 Old 02-23-2010, 09:45 AM
RubiZealot's Avatar
Between my lift and my spare, I can't see anyone behind me anyway.
Bright away!
post #21 of 22 Old 02-23-2010, 09:59 AM
H3ATH3N's Avatar
I am thinking about going with these mounted along the back of my GOBI rack. I like the LED because of their power consumption-light output ratio. Should work, no?
H3ATH3N is offline
post #22 of 22 Old 02-23-2010, 04:01 PM
usmcdoc14's Avatar
thats the "other" reason main reason is when I am hooking up winch/strap at night or need "on" rear lighting.
The best ones I have found are believe it or not but the cheap ass "utility" rubber housing round lights from Harbor Freight They have good flood and are durable. And when you back one into a tree you do not feel bad
http://www.harborfreight.com/cpi/cta...emnumber=93904
