wiring question / help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 02-21-2010, 02:29 PM Thread Starter
I am trying to wire a pair of KC driving lights (JK 2010 4door), got most everything donr, mounted the brackets, lights, wire harness to the lights, relay, battery, BUT am stuck with getting the wires into the dash area for the switch??
The directions say to just run the wires through the seam between the hood and open door, but then they would be pinched by the door when closed??
Looked for some way to go through the fire wall into the cab, but don't see any easy way. Can anyone help?
JP
pemberton is offline
post #2 of 3 Old 02-21-2010, 05:31 PM
usmcdoc14's Avatar
drivers side remove the side panel from the dash, you will see the cast aluminum "dash" attached to the firewall and a 1/2" hole filled with expanding foam.
Poke out foam, run wires.
Or run wires under cowl and under windshield frame at the door as there is a gap
usmcdoc14 is offline
post #3 of 3 Old 02-21-2010, 05:41 PM
usmcdoc14's Avatar
sorry I did not see you already cross posted this in this forum. next time pick a forum and stick with it.
