Locker bypass - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 12-22-2014, 09:56 PM Thread Starter
Locker bypass
Quick question about the locker bypass.. I did the grounded method I found under write-ups and so far so good, I only did the rear as I don't want greater my chances to breaking the fronts with speeds. Anyways I'm just wanting to know if the lockers work same as factory if I leave my bypass off when I put jeep in 4Lo and hit the factory locker button?
OCOutdoors is offline
post #2 of 3 Old 12-22-2014, 10:11 PM
ronjenx's Avatar
If you did the one where all you do is supply a ground for the relay coil, yes it will behave as normal as long as your new switch is open. You will still have normally functioning OEM switches.
ronjenx is offline
post #3 of 3 Old 12-22-2014, 11:15 PM Thread Starter
I just spliced into purple wire with green stripe under fuse box. I guess I could just try it and see!!
