Auxiliary power port - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 12-21-2014, 09:24 PM Thread Starter
Is there a way to wire or a fuse so that the auxiliary power port could be used even when key isn't on? For instance so I could charge my phone in the jeep without having the ignition on?
OCOutdoors is offline
post #2 of 7 Old 12-21-2014, 10:28 PM
Ronson's Avatar
One of the 3 in my 2012 has a fuse that has 2 positions. One is to keep it on all the time, the other only when the key is on.
I can't remember which one because only one of mine works but I think it was the one in the console.
Ronson is offline
post #3 of 7 Old 12-21-2014, 10:32 PM
BumpInTheRoad's Avatar
By default, the passenger-side power outlet on the center dash is always on.
I'm a JKO Reject
BumpInTheRoad is offline
post #4 of 7 Old 12-21-2014, 10:50 PM
ronjenx's Avatar
According to the 2012 Owner's manual...
The outlet on the right side of the center section is on when the key is in ACC/RUN positions.
The outlet in the console is always on.
The outlet in the rear cargo area (if equipped), is selectable for always on, or on with the key in ACC/RUN positions.
Be careful with those small chargers. The have been known to malfunction and start fires. Somehow they know when they are left unattended.
ronjenx is offline
post #5 of 7 Old 01-05-2015, 02:43 PM
It has been correctly mentioned earlier that these ports are not bypassed by car manufacturers since they can be hazardous when left unattended. It is also because usually when a vehicle is started, the self-start mechanism produces a current surge which can cause failure to any electronic circuitry attached to the charging port. You can take a small multi-meter and check which fuse is shorted with the charging port.
carkifelek is offline
post #6 of 7 Old 01-05-2015, 03:22 PM
Ronson's Avatar
I checked the fuses (in fact I checked every fuse) and they are all good. I think I melted some wires. One of these days I will chase it down...
Ronson is offline
post #7 of 7 Old 01-06-2015, 05:08 AM
warcop's Avatar
Send a message via Yahoo to warcop
This is not by any means a cheap option but if you could wire it through an SPOD. Another option is to wire it directly to the battery with an inline fuse and a switch.
Warcop
2012 JKU Sport, Rock Krawler 2.5 Flex, Smittybilt SRC Side Armor, Mesh Grille MOD, Sony Double DIN AV Receiver, Back up Camera, Kicker Speaker Upgrade, ARB Twin Compressor, Dominion Off Road High Lift Mount, Homemade Paracord Grab Handles, Nitto Trail Grapplers, Paramount Rear Bumper with Tire Carrier, KC Hilites Daylighters, under seat lock box, Metal Cloak Front Bumper, BARTACT Seat Covers, BARTACT Sun Shade, x20 Comp Winch, sPOD, ARB Air lockers, 4.10 Gears.
warcop is offline
