07 JK 3.8L - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 12-13-2014, 03:03 PM Thread Starter
07 JK 3.8L
Hi,
After installing flashpaq 3872 programmes and fiddling with running light settings amongst other things I now have a small issue.
When braking the amber turn signal lamps are on instead of the red brake lamps. I believe this is how it may work in the USA but I would like to return it to the way it was.
Returning everything to stock using the SC programmer did not help. Any ideas?
jturnerza is offline
post #2 of 3 Old 12-13-2014, 09:13 PM
LoneJK's Avatar
welcome to jko, and no, here in the USA we use the red brake lights. the amber are just turn signals... try checking each setting for each light.
i also have an 07 3.8L JK
"Gremlin"
LoneJK is offline
post #3 of 3 Old 01-11-2015, 10:51 PM
b1pig's Avatar
the programmer has little to do with the electrical....
i'd bet you have a bad ground... bad bulb or something...
your other option is to return those settings to stock.
b1pig is offline
